07-06-2010, 12:13 PM | #1 | ||
ford lover
hi guys i have a au3 sr wagon i have a grind in the brakes its only when brake pedal is pressed it happens now and then i have put new brake pads on and new rotors i need help to work it out
07-06-2010, 01:18 PM | #2 | ||
When in doubt, GAS IT!!
Could be a stone lodged in a caliper.
Bushbasher
07-06-2010, 01:26 PM | #3 | |||
Back to Le Frenchy
Mrs has the same issue on her car.
Apparently some cheaper brand pads can make this noise due to the compound they use.
07-06-2010, 01:50 PM | #4 | ||
Just another mock-up..
i had the same problem...
what pads did you use..? i changed my pads to bendix and the noise stopped.. some brake compounds are utter rubbish...
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
07-06-2010, 05:49 PM | #5 | ||
Stroking it...
My AU does the same on the front, but I have AP Racing "race pads" which are a fairly hard compound, dare say your issue could be related to the pad compound..
Had: 347ci AU Then: Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
07-06-2010, 07:04 PM | #6 | ||
Formally kotevski22
Take the pad back and buy bendix,should fix you're problem.
08-06-2010, 09:41 AM | #7 | ||
ford lover
the brakes are bendix and there is no noise but a grinding like metal to metal and felt through the pedal only when bakes applyed
08-06-2010, 09:53 AM | #8 | ||
front or rear...
have you sat the discs on properly..? i once saw a guy who had done his brakes, not sit the discs on properly and they were rubbing on the caliper..
08-06-2010, 09:55 AM | #9 | ||
ford lover
sounds like front
08-06-2010, 09:56 AM | #10 | ||
ford lover
it was doing it before i change everything
08-06-2010, 09:57 AM | #11 | ||
so it was grinding before and after the disc and pad swap...?
08-06-2010, 09:59 AM | #12 | ||
ford lover
yes and some times the abs light comes on
08-06-2010, 11:05 AM | #13 | ||
thats a bit of a worry, brakes are not something to experiment with, no disrespect intended but i think i would be after a proffesional opinion.
08-06-2010, 11:06 AM | #14 | ||
Yeah agree totally..
after reading about the ABS light.. i think its off to a specialist for you....
08-06-2010, 04:15 PM | #15 | ||
ford lover
i know the rear pads are close to be replaced would it cause this problem
08-06-2010, 04:17 PM | #16 | ||
if they're metal to metal then yes...
not if they're just close to needing replacing.. best bet is to see a brake specialist.. too hard to diagnose over the net mate.. need to hear and see it..
08-06-2010, 04:28 PM | #17 | ||
ford lover
ok thanks
08-06-2010, 04:31 PM | #18 | ||
no worries mate..
good luck with it!!
08-06-2010, 05:06 PM | #19 | |||
FG GT 5.4 w/ additions!
What pads are they exactly? I have the Bendix General CT's ( Ceramic) in the missus car and under hard braking especially when close to a stop or slow speeds they have this horrid grinding sound. Sounds like the pads are worn out and starting to grind metal on metal. From many sources I have been told this is normal for a pad of it's type.
I agree too, best to seek professional comment as without seeing them I could be waaay off the mark.
