Old 05-08-2010, 06:10 PM   #1
EV1LXR8
EV1LXR8's Avatar
Default low oil pressure at idle
when my xr8 s1 warms up to running temp and i pull up to a stop the oil pressure drops down allmost to the red i just did a new filter and oil valvoline XLD premium 20w-50 i take off again and the pressure will build up to normal again, i have been looking at the Z89A filter, will this fix my problem? i have a z9 in there at the moment, it drops pressure so fasr sometimes that it warns me of low oil (red marker it beeps 3 times at me) can anyone help
EV1LXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 06:32 PM   #2
mik
mik's Avatar
z89a is the listed filter for the v8, i`m unsure what the difference is between the two(z9) , a mate has an au fairmont v8, his also has the low oil pressure at idle ,although it does`nt seem to affect it, it would be interesting to see an aftermarket oil pressure gauge hooked up to see what the pressure really is.
Old 05-08-2010, 07:39 PM   #3
GK
Walking with God
GK's Avatar
IIRC, the Z89a is smaller keeping more oil available in the sump.
The capacity of the Z9 is 600mls or so.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 05-08-2010, 07:55 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
i love when you buy a z9 and it says falcon 1960-2005
funny thing with the z9's is they come with their own post code they're that big
Old 05-08-2010, 08:01 PM   #5
Cam
Stroking it...
Cam's Avatar
AFAIK The AU gauges never move, unless there is NO oil pressure at all.. Although never sat in an AUI XR8, so may be different..
My guess, Either that or the sender is rooted / the connection is loose, has come off, or is full of crap.. The same has happened to me..
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 08:02 PM   #6
KR1STO
Just another mock-up..
KR1STO's Avatar
Series one was a proper gauge Cam..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 08:06 PM   #7
Cam
Stroking it...
Cam's Avatar
Thanks Kristo, wasn't sure when the "real" gauges stopped..
Had: 347ci AU
Old 05-08-2010, 08:07 PM   #8
KR1STO
KR1STO's Avatar
no worries mate..
see my car here:
[SIGPIC][/SIGPIC]
Old 05-08-2010, 08:11 PM   #9
mik
mik's Avatar
GK
aaah ok, thanks GK.
Old 05-08-2010, 09:32 PM   #10
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
GK
Thats funny.....The Z89 is for the the 220kw & 250KW versions which run a oil cooler.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2010, 12:32 AM   #11
KR1STO
KR1STO's Avatar
Yep, It's used because the Z9 wont fit when the oil cooler is fitted...
see my car here:
[SIGPIC][/SIGPIC]
Old 06-08-2010, 03:01 AM   #12
GK
Walking with God
GK's Avatar
Some good extra discussion here.
Kristo is on the money, the S1 had the proper gauge.
Correct me if I’m amiss here, but the S2-3 items work like an on/off deal, where the gauge shows you’ve got correct pressure (meaning some pressure) or none!
Cam, if your gauge shows nothing, then I reckon it’s a loose wire or otherwise as you’ve suggested.
Okay, never heard that connection being discussed before. I've only heard general talk about V8 guys going from Z9 to Z89 to sure up pressure. That's good info. JC has a 220, I wonder what filter is on his? And also whether he's got an oil cooler running?
So then, if the OP has a Z9 on his V8, and if Craig and Kristo are correct on the reasons for the Z89 over the Z9, then perhaps it’s just for him a matter of having oil a little too thick for winter? He does have pressure, but it drops off on idle.
Here's his post again.
So it's a S1 therefore with no cooler.
EVILXR8, when you went the 20w/50, is that the same viscosity you have used previously? Same brand?
If you upped the viscosity and have always run Z9 filters, then I'd assume it's the oil. If you've run the same filter and oil (viscosity and brand) as previous, then you've probably got another problem.
Hope my reasoning here makes sense?
GK
Now gone!
On LPG
Old 06-08-2010, 09:10 AM   #13
mik
mik's Avatar
how many K`s has your engine got on it Ev1lXr8?
Old 06-08-2010, 04:32 PM   #14
EV1LXR8
EV1LXR8's Avatar
260xxx on the clock, i had 15w 40 for my last batch of oil, (put in by mech) i can fit a z9 in (just). not sure if it has an oil cooler. its an ex chaser so it got added bits and peices. different brand filter and oil
here are a few pics not sure wawt a cooler looks like
this last pic is some sorrta cooler in front of the radiator not sure wat its for is it an oil cooler?
thanks for the help also guys
Old 06-08-2010, 05:51 PM   #15
GK
Walking with God
GK's Avatar
I'd say drop the oil and go back to 15w/40 or a 15w/50 oil.
GK
Now gone!
On LPG
Old 06-08-2010, 08:07 PM   #16
Tickford Kid
Formerly known as TS 50
Tickford Kid's Avatar
Series 1 AU XR8's had a problem the earth on the engine that made the oil pressure gauge play up.
It has been a long time I owned an XR8 that done this.
Do a search about it. There was a technical service bulletin about it.
The problem isn't with the filter.
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
Tickford Kid is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2010, 08:17 PM   #17
Cam
Stroking it...
Cam's Avatar
Yeah actually, now you say it i remember reading it. rep+
Had: 347ci AU
Old 07-08-2010, 01:26 AM   #18
GK
Walking with God
GK's Avatar
Certainly worth checking out for sure.
Remember though, that his oil pressure issue only started after using a thicker grade oil.
GK
Now gone!
On LPG
Old 07-08-2010, 01:50 AM   #19
EV1LXR8
EV1LXR8's Avatar
i red in an old post that you can put an extra 500ml of oil in and that apparently help with the pressure, any dangers to this? it was doin it b4 the oil change but no where near as much as its doin now, also i brought a z89 filter so waiting for that to arrive to put it in, ill check out that tech post, cheers
Old 07-08-2010, 07:32 AM   #20
GK
Walking with God
GK's Avatar
Okay, so thinner oil, checking your oil pressure sender and the smaller filter should see you through! LOL!
All the best with it.
GK
Now gone!
On LPG
Old 07-01-2013, 12:31 PM   #21
phil ford
Default Re: low oil pressure at idle
This is an old thread, but did anyone ever resolve this issue?
I have exactly the same problem, same car xr8 au1, been doing it for nearly 12 months now and engine still going fine. My mechanic has no idea; replaced oil switch; still doing it.
Frustrates the hell out of me.
phil ford is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2013, 12:09 AM   #22
AUFanboy
It's most likely an earthing issue with the gauges. Add a nice fat ground cable from one of the alternator mount bolts to somewhere solid on the car's body. You can also go to the negative battery terminal, but it's better to go to the body because most of the car's electrics (including instrument cluster) ground to the body, then the current has to get back to the alternator casing (which is the ultimate ground when the engine is running). Supercheap Auto has some nice cables with pre-crimped lugs.
AUFanboy is offline   Reply With Quote Multi-Quote with this Post
