Old 21-08-2010, 04:19 PM   #1
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Default 5L Fuel Pressure Guage
Got a fuel pressure guage that scews on to the std 5L fuel rail so just thought id post the link along with a couple of picks in case anyone is in the market.
http://www.jegs.com/i/JEGS/555/41016/10002/-1
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2010, 04:37 PM   #2
JK EX CHASER
Formally kotevski22
JK EX CHASER's Avatar
Looks neat good job.
JK EX CHASER is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2010, 06:14 PM   #3
CRAIGAU3220
Cat be Still !!!
Cheers. Heres a pic at idle.
Old 21-08-2010, 10:25 PM   #4
philstoj
philstoj's Avatar
Running at high pressure, they should be around 37 psi from memory?
Old 22-08-2010, 12:17 AM   #5
CRAIGAU3220
Cat be Still !!!
Yes i thought so too, that pic was taken on first start up after fitment, since then Ive been out and about a bit and had a few peeks and seems to be running about 44psi, this is with standard 220 reg which i believe is set at 41psi
I also got from JEGS a Aeromotive adjustable reg which will get fitted once i get a good average from the gauge at static (no vacuum) pressure.
Cheers, Craig.
