Hey guys. I have replaced the battery in the key fob of my 06 WQ fez and of course now it doesnt work! Do I reset it? How? I have tried II to I 4 times 3s, II to 0, nothing. AAArgh. Also does the positive face upwards. Thanks.
I went from a 05 comm wagon to the fez. 550 to 600k 45l from 450 to 480k with 75l. Does me, and 100 times more fun to drive. |
Lil Henry
I have replaced my battery before without having to retrain the key fob. perhaps try flipping the battery over from memory the flat side of the batter faces up towards the back of the fob. and to retrain go from 0 to II quickly several times it should beep to let you know its in training mode
Lil Henry
just tried it on my car 0 to II rapidly 4 times on the key it did one long beep
Thanks Kariharnett, will try again tomorrow. I was definitely not getting a beep. I was going from 0 to II, then II to 0 4 times. AAArgh. I probably took too long to put new battery in hence blanking it. Opening the fob the plus is facing me, it seems easier going in this way. Do you believe it, the moment I pulled the old battery out I forget which way it was in. All that schooling for nought. LOL.
Mate I have a used replacement if you want it for few dollars from my old WQ I had a spare ... One trick dont mix two keys and two key fobs once they are programed and as each key has it own code to the fob. My fob would have to be programed to your key
I now have a 2010 WS if your wondering and I kept the spare fob
How much for it Fez WQ?
Lil Henry
yeah sorry i just opened my key up and your right positive faces towards the buttons.
NOOOOOOOOOOO!!!!!! I mean YESSSSSSSSSSSSSS!!!!! I have just discovered that I had the wrong battery. The one I bought is a DL 2032, WRONG. It should be a CR 2032. Both the same size and both 3 volt. Off to the shops tomorrow.
#10 | |||
email me if you want it aaronhunter@iprimus.com.au |
