Hey guys,
Does anyone know where i can find the engine number on an AU motor? Im under the impression that it is stamped somewhere, but cant for the life of me find it. What i thought was the engine number, was actually the casting number ![]() On that note, when you do an engine swap, how important is it to let Motor reg know that you have done it? Cheers
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| |
i think its on the extractor side and the front of the block under the power steering pump and above the alternator
i did a engine swap on mine, but it was still registerd, just have to let them no the that u changed it over with another engine , then they will check the number to see if its stolen or not etc
back of the block near the bell housing on the exhaust manifold side
woops sorry about that, i just looked and falcon oath is right, must the the e series which have it at the front then
![]() Join Date: Nov 2007
e series is in the same spot.
