Hi guys....
the seat hight adjustment joints under the driver seat start to creak when the car gets older. I tried silicone spray, WD-40 and Vaseline but nothing worked. It is the rear part of the hight adjustment which creaks like mad and it is driving me nuts. The front part of the hight adjustment is fine. Can anybody suggest some other oils, potions or solutions to get rid of that creaking? I think over the years the metal base of the seat and all the joints get loose and there is no way to tighten them. Thanks The Moose |
*SILVER SERVICE PILOT*
![]() ![]() Join Date: Jul 2006
Bit late, but you might have a cracked seat frame...standard equipment on B series
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
#3 | |||
ROCKING THE EL FUTURA
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
Hi there....
well...I really had a look and it is not a cracked seat base....all the joints and bolts of the hight adjustment is just fiddled out a bit (bigger tolerances from when it was new). You might laugh...but you know what I did ? I got a dark cotton string and wrapped and squeezed it arround the joints. Silence... That also works for rattling air vents once you took them out. A thin threat wrapped arrond the joints to keep them in place firmly.... It is fiddely work but I am a picky one. The Moose |
I think I have the same problem. I cant see any cracks on the seat base.. Did that fix still work after all this time Swedishmoose? I havent been able to find a post where anyone seems to have fixed the problem
Next upgraded Mk1 Leopard
my wife told me to lose weight
![]() UK
I'ma bit ssurprised mine hasn't got the seat squeaks, i was a fairly large fella around 145 kgs, been cutting back on the burgers ,a tad lighter now about the 130 mark
![]() How's the rebel goin UK? Dam...... I nearly bought one of those a couple of times last year.... .This close fair dink um ![]() |
