Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 16-12-2010, 11:59 PM   #1
music189
Default experts help please
Hi we have debate raging on the Terri site about fitting front pads some guys are advocating clamping brake hoses and even DBA has a tech quide on you tube showing clamping a hose.
I was always under the impression as a trained mechanic clamping hoses was a big no no as it can damage the reinforcing
I have always cracked the bleeder to push back the pistons. do you have any thoughts .
http://fordforums.com.au/showthread.php?t=11316998
music189 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2010, 10:05 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Clamping brake hoses on cars has been done for many years and is also a great way to try and locate a problem with the brake system as it will isolate certain areas when the hoses are clamped.Braided lines can't be clamped.
There are however certain things to be aware of when clamping hoses as any tool that has sharp edges will cut into and damage the brake hose. Also check brake hoses that seem to look worn or frayed as these hoses will generally be softer and may also have further damage caused by hose clamping so there can be issues when doing this but generally speaking it is fine to clamp rubber brake lines.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
