Old 28-12-2010, 07:42 PM   #1
Pavey
Pavey's Avatar
Default AU Spoiler Removal
Had a look around and all I could find was the tutorial on aufalcon.com
It says to unplug it at the side of the boot latch. I've done that but its not attached there. It goes from the spoiler into a rubber tube and into the body somewhere in the parcel shelf. So just seeing if anyone has had the same problem and has a solution?
Pavey is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2010, 11:05 PM   #2
T3man
T3man's Avatar
I'm assuming you are referring to the wiring for the spoiler.
If so there are two solutions.
One is drop the parcel shelf under cover; then remove the parcel shelf itself and you will find the plug on the driver's side tucked away in the corner next to the C pillar.
The other way is to cut the wires midway along the rubber insulator and if needed they can be re-joined at a later date.
