Old 03-01-2011, 02:11 PM   #1
Tanjiv
Default Ford cougar
Hi,
I have a yr 2000 ford cougar I recently bought. Been having a slight problem where there is a knocking sound when I accelerate from stationary position. The sound ceases once I go past gear 3.
Tanjiv is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2011, 02:12 PM   #2
Tanjiv
Does anyone encounter the same prob or have an idea of what it might be?
Old 04-01-2011, 02:43 PM   #3
thearrow
It sounds like a bearing issue......I was getting a clicking noise and it turned out to be the front CV stub axles and was fixed when I replaced them.
Get your mechanic to check it out.
Owning a Cougar is like owning a Super Model
Good to own but "High Maintenance"
2000 Model Eibach Cougar (Auto) - Now dead & buried
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2011, 05:43 PM   #4
Tanjiv
Thanks for your help, would you know what would be the cost to replace them?
Old 05-01-2011, 11:44 AM   #5
thearrow
I get all my parts shipped from here http://www.rockauto.com/ and can advise 2 x Half Shaft Axle Assemblies = U$230.00 + shipping = U$196 = Total U$427.00 plus A$200.00 for fitting. Not cheap but it had to be done.
Since this repair has been completed I am getting much better fuel consumption now showing on the read out as over 447km per tank. I know, I know it is just an average but it has been quite noticeable on the road that my fuel consumption has dropped substantially.
If it is this problem you should hear a "clicking" noise when you drive next to a wall or solid road barrier. If you are not hearing this then it is some "other" problem.
Let us know what happens.
Old 08-01-2011, 02:34 PM   #6
REDDYZ
REDDYZ's Avatar
I could be the rear trans mount or drive shafts too. Is that a continuous clicking sound or just intermittent knock sound? Before you buy anything its a good idea to find out the actual problem. Try driving in circles with steering full lock and see if the sound gets worse. Try both left and right. It should make more noise when you turn becoz thats when CV joints do their job. This way you will also know which one is gone. You can replace them individually means left inner, left outer, right inner, right outer and center shaft. If it is outer ones then you can get away cheaply. If it does the sound only in straight line it could be bearings or mounts.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2011, 01:21 AM   #7
Tanjiv
Thanks so much for yourhelp, will send it toy mechanic soon n let you all know!
Old 12-01-2011, 03:37 PM   #8
Dshibi
A New Focus In Life...
Dshibi's Avatar
Hi Tanjiv,
Welcome to the Cougar owners group! Agree with the above posts on what might be causing your knocking.
How's the car apart from that? Enjoying it?
Dan
2010 Ford Focus XR5T - Performance Blue
2XS - Continental - Dreamscience - Elevate - PumaSpeed - Whiteline - XForce
Dshibi is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2011, 09:26 AM   #9
Thunderbird
Also check your sway bar links and the lower control arms. Those 1/2 shafts are available cheaper here then in the USA too & at least it they are not right you could return them.
I had a knock unknown, on acceleration, then cornering, turned out to be the sway bar ball link joints mainly but one wheel bearing was shot or on the way out that didn't help.
Thunderbird is offline   Reply With Quote Multi-Quote with this Post
