10-01-2011, 07:14 PM | #1 | ||
O8 ranger 4x4
hey,
i own a au wagon series 2 and my rear seat center seatbelt isnt working id say like jammed, worn retract or anything and advise on how to access it belt would be great it seems to be inside the frame of the seat? please help thank you |
10-01-2011, 07:18 PM | #2 | ||
make sure the seats are locked back.. and on the flat.. then try again
10-01-2011, 09:41 PM | #3 | ||
Hi. Try sending a PM to Linz (the "Mercury man"). Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
10-01-2011, 09:52 PM | #4 | ||
Hi.mods can delete/double post Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote Last edited by foxtrot3; 10-01-2011 at 09:54 PM. Reason: double post |
11-01-2011, 05:55 PM | #5 | ||
*SILVER SERVICE PILOT*
PM received and replied (cheers Michael).
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
13-07-2015, 11:05 PM | #6 | ||
So what was the fix? I need to know myself now.
13-07-2015, 11:37 PM | #7 | ||
Remove lower seat base and undo mounting bolt and let the seatbelt retract a bit to release the inertia ball then refit seatbelt mount. Make sure you use Highways recommendations. I have done this heaps usually on commondore wagons. It locks when seats are folded down and inertia ball locks closed and only tightens it even more when seat is raised back up. Hope that helps and long time between drinks on this one.
14-07-2015, 09:15 AM | #8 | ||
Thanks, I'll give that a go....
Discovery: you can undo the little buckle thingy at the bottom with by pushing a pin into a small hole that I didn't see in the dark. Inertia reel still stuck. |
14-07-2015, 10:22 AM | #9 | ||
Correction, all fixed now, also made sure the plastic pimple on the belt is outside the plastic trim bit at the top.
