Ford 4 Life
Hi All,
All of a sudden today, my wifes AU has no break lights, No on rear pacelf shelf, spoiler or tail lamps all not working . I have changed the Rear globes & fuses, still nothing ..i have also changed the relay with one from my BA falcom and nothing, all other lights still working ..Only ALL the brake lights have packed it in..any ideas ?
-------------------------------------------------- [CENTER]NEW - BA XR6 FalconFull Leather , Sunroof, 5 Speed 2nd Car - AU Falcon , Black Tickford wheels and Bodykit ---------------------------------------------------
check the trigger switch on the pedal
Ford 4 Life
Thanks for the suggestion ,
I checked the switch, pulled it out and cleaned it and the lights worked last night with no problems.. After driving for a little while this morning, Of they went again... Could the switch be faulty ? ...are they replaceable and if so can they be bought in auto shops ?
Yes faulty switch just grab another from bursons, happened to be recently about $15-20 has been working fine since.
Also check the cables coming to the switch as well... (green and a black one from memory) They go into a black clip setup, that then clips to the switch.
Mine were hanging down and rubbing on something and it had split... I went out, bought a new switch, and nothing, then realised what it was while doing to yoga act it is to get underneath it...
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| Last edited by Cadge; 14-02-2011 at 04:22 PM. |
Ford 4 Life
cheers ill give it a shot, thanks heaps for the help
CYCO4D Wagon.
They suffer from the switches mate, I had to do mine in the wagon, I only had lights when I had the pedal pressed all the way down and the car was stopped.
www.aufalcon.com.au/cyco4d |
