Hey guys, I had a look in the AFF Technical Docs but couldn't find anything specific.
Im going to be replacing my cracked radiator tomorrow in my AU2 XR6 (manual) with a new one. I am assuming the procedure to remove the old radiator will go something like this: 1. Drop coolant and remove all hoses 2. Unbolt condensor assembly from radiator 3. Unplug wiring harness to thermo fans 4. Unbolt radiator assembly from car 5. Remove radiator and fans as one unit Does this sound feasible? It looks easy enough to get in behind the grill to unbolt the condensor from the radiator. I am then going to remove the thermostat, and flush the block with the engine running (with the heater on). I will then fit the new radiator, and flush the whole system a few times again. I was thinking I could re-attach all the hoses, except the top hose where it joins the thermo housing. I could point the top hose to the ground, put the garden hose in the thermostat housing and flush the system like this. Would this work or does it need to be done opposite? Then I will fill with coolant and demineralised water, and drive... The radiator shop is going to pressure test for me on Monday. Any tips or hints will be much appreciated! Thanks, Mark |
Flairs - Truckers Delight
I'd be removing the thermo fans before removing the rad
it's really quite a simple job
mate ,i have an au with the standard grill and found removing that made it heaps easy to get the top to bolts for the condensor (ac thing).
actualy if you want to buy a tool thats worth its weight in gold ,go to repco or autobarn a buy a 10mm spanner with that socket stile ratchet system at the end .fits a lot of tricky areas other than the radiator /thermo's/condensor.best tool i ever bought. its a pretty easy sort of job to do . ps. to flush the system ,there is a bung plug on the base of the radiator to flush it.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
#4 | |||
[SIGPIC][/SIGPIC]
![]() Join Date: Dec 2006
One thing I always do is turn the bottom radiator hose clamp to face up, so you can get to it from the top rather than underneath.
Usually means removing the tray. If it has never been removed they will have little round caps on them, just pry off to see the screw head. |
not here much anymore
I'm going to tackle this on a V8 this weekend and I think I am pretty right with getting the radiator out but I am trying to find some info on the best way to flush the block while I have everything apart.
Am i right in thinking that if i drop all the coolant out of the radiator by opening the bung in the bottom of it, leaving it open, and then putting the hose into the coolant resevoir, running the hose and running the car with the heater on, that it will flush all the block and hoses? Or should I do it another way? First time I've done this so all a bit new to me.
RAM 1500
#7 | |||
Sales Representative
Either buy yourself a flush gun (uses water and compressed air) or use my washing soda technique.
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
#8 | |||
RAM 1500
#9 | |||
Here's a great how to guide with photos in pdf form. Really helped me out when I did my radiator a couple of months back.
File name: ebook_-_radiator_replace.pdf File size: 1.24 MB |
#11 | |||
this link seem to be out dated is it possible to get link to this file Thanks JaTT |
2 users like this post: |
#12 | |||
Travis - 1999 Ford AU S1
Trying to track down Hot Chilli Red (Not Maroon or Burgundy) AU Ford car parts & Fairmont Ghia parts. PM me if you have something. |
#13 | |||
