Old 24-05-2011, 08:05 PM   #1
adublu
Default Power windows relay stays on
Hi all,
I have just converted my au ute to power windows, following advice from other threads on this site. It was fairly simple thanks to these forums.
However, I have noticed that when I turn the ignition acc on, the relay clicks on and stays on as long as the ignition is on. After turning the ignition off, it stays on for about another 45 secs, then clicks off. The windows themself work fine.
Is this right? I amm just wondering because the relay gets very warm.
Thanks
adublu is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2011, 09:30 PM   #2
bodes-sh
Default Re: Power windows relay stays on
sounds normal. the bem controls the window relay and it gives you a delay when you remove the key in case any windows aren't fully up, saves having to turn the ignition back on to put them up
Old 24-05-2011, 09:49 PM   #3
foxtrot3
foxtrot3's Avatar
Hi. Yes this is normal just make sure you used a high quality relay and you wont have any problems. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2011, 07:26 PM   #4
adublu
Oh cool Thanks Bodes and Foxtrot
At the moment I have the demister relay in there will get around to buying one soon
