Old 04-11-2011, 02:47 PM   #1
xp_wannabe
xp_wannabe's Avatar
Default Genuine Ford Suspension Bushes
Trying to come up with a plan on renewing the suspension on my ute. (AU2 XR6)
Not keen to go polyurethane or aftermarket rubber, so have gotten some quotes from the local dealer on genuine stuff:
Front:
Lower Control Arm bushes - $504.25 for all of them (both sides)
Top Control Arm bushes - $79.95 for all
Rear:
Rear Leaf bushes - $76.15 for all 8
Front Lead bushes - $88.04 for both sides
This doesn't seem to bad to me, especially since I could most likely get better prices with a bit of hunting around.
Would like to hear from people who have gone down a similar path...
Thanks, Mark
xp_wannabe is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2011, 03:43 PM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: Genuine Ford Suspension Bushes
and those prices are plus fitting too?
or are you doing it all yourself?
can you buy a complete lower control arm with all bushes fitted, brand new from Ford?
might be cheaper than buying all the components, then paying for the pressing in/on etc, and then paying someone to fit them to the car too.
and most likely a wheel alignment after thats all done...
a guy i met a couple of months ago took his AU ute to ford and had all of the suspension bushes and 2 struts, 2 shocks supplied and fitted at Ford.
it cost him $2600 all up.
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2011, 03:49 PM   #3
xp_wannabe
xp_wannabe's Avatar
a guy i met a couple of months ago took his AU ute to ford and had the bushes and shocks supplied and fitted at Ford.
Im going to do it myself and I have a press etc.
Will do whiteline 27mm sway bar at the same time on the front so will do the bushes for that in nolathane and also sway bar links.
guess i should do the caster/camber mounts at the same time too... forgot to get a price on them from ford...starts to add up lol!
