Old 27-12-2011, 09:15 AM   #1
dieseltrain79
Default Ebay AU Radiator Overflow Tank
Hey peoples , Just installed 1 of these from ebay . NON Genuine item i know , but its failed in les than 1 hour . Wont hold pressure and spews coolant out of the neck that the cap Sits on .
Seller is Located @ Smithfield , will be paying them a visit . However it leaves me needing to go to the wreckers today to chase one up as the wife needs her car fo the kids .
Anyway , just a bit of buyer beware i guess , or im unlucky
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2011, 10:47 AM   #2
4ford
Default Re: Ebay AU Radiator Overflow Tank
Are you sure the pressure rating of the new cap is correct, or maybe you could use the old cap on the tank.
Historically, the main problem with AUs venting coolant has been the cap!
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2011, 01:19 PM   #3
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
+1, make sure the rad cap's good first
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2011, 03:30 PM   #4
Cam
Stroking it...
Cam's Avatar
+ 11tynine the cap
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2011, 07:41 PM   #5
irdonn
irdonn's Avatar
Got a link for it mate? I also purchased a non genuine off fleabay and it's all good. Using the old cap.
06/01 AUII XR8
irdonn is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2011, 07:47 PM   #6
Mechan1k
Mechan1k's Avatar
But a B-series one in as a replacement ... I got from Macarthur Parts plus for about $40 with factory screw in cap. Worked a treat ... and clean.
I did have to change the lower hose out of the header tank as it is located differently ... but that was just a B-series one. One the shorter hose from the top of the header tank to the radiator needed to replaced with a longer one (I just got another thermostat housing to header tank hose and cut it to length)
Old 29-12-2011, 10:14 PM   #7
dieseltrain79
New cap and old cap same thing . Always going to be a dud in a batch i guess , what can ya do .
New cap is rated at 135
Old 30-12-2011, 12:38 PM   #8
Day-mow
rexnet
Day-mow's Avatar
do the B series ones fit? my folks B series tank looks so much cooler then my AU one. mine needs replacing anyway
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
