Old 27-12-2011, 07:46 PM   #1
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Default AU3 Dash Removal
So I am going to pull the dash out of my car on the weekend to clean out the evaporator.
Is there a tute someone has done at all?
Old 27-12-2011, 08:04 PM   #2
T3man
T3man's Avatar
Default Re: AU3 Dash Removal
What makes you think the evaporator needs cleaning? I wouldn't be pulling the dash unless the whole heater box needed replacing for a leak or such. It can be flushed while in the vehicle and I don't see how taking it out will make it any easier really.
Anyhow, is it high or low series dash?
Old 27-12-2011, 08:51 PM   #3
MNM96
MNM96's Avatar
Can I clean it without removing the dash?
The air flow is restricted because of dust or whatever?
It is an AU XR6 SERIII.
Old 27-12-2011, 09:25 PM   #4
T3man
T3man's Avatar
I guess it's possible to be blocked by leaves at the intake/plemun - unlikely to be an internal problem with the heater box or evaporotor.
If it's a blockage by leaves externally I'm not sure the best way to clear it.
If you end up having to remove the dash to get at the heater box you can PM me and I'll send you some detailed instructions. Before you even start though you need a stereo removal tool so let me know that you have that first.
Old 28-12-2011, 07:07 AM   #5
MNM96
MNM96's Avatar
I have checked the intake is clear. Years ago I used to clean out a cabs evap on an el falcon, which was easy.
I believe the issue is just a build up of dust on the fins building up since new.
I have the radio pins. If you want to email me I will send an address. Thanks.
Old 28-12-2011, 11:02 AM   #6
T3man
T3man's Avatar
Cheers mate - got your PM and when I get home tonight I will send you some detailed instructions.
Old 29-12-2011, 07:08 PM   #7
T3man
T3man's Avatar
You have mail ....
Old 29-12-2011, 08:20 PM   #8
MNM96
MNM96's Avatar
Originally Posted by T3man
You have mail ....
Thanks Jeff. Wish me luck!
Old 02-01-2012, 08:45 PM   #9
MNM96
MNM96's Avatar
Info from T3man ; Tick!
Dash Out ; Tick!
Dash in ; Tick!
Dissapointment ; Tick!
What a depressing weekend!
