Old 30-12-2011, 04:03 AM   #1
EFinSilver
Default Which Fuel & Oil Combination are you using?
Curious to know what others are using in their E series.
On the EF Fairmont with just over 250,000 on the clock, I'm running Shell Helix HX5 15w-40 and for fuel just topped up 98 premium.
EFinSilver is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2011, 04:17 AM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: Which Fuel & Oil Combination are you using?
Oil: Liquimoly 10w40 (unable to confirm, but that is what I was told was put in last service)
Fuel: always 95, or only if I have to, 98.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2011, 01:38 AM   #3
EFinSilver
how come 95?
Old 31-12-2011, 01:42 AM   #4
XRGhia
meh.
XRGhia's Avatar
Umm... Just that on BP 98 (I have AU XR fuel reg, injectors and AU XR6 VCT engine with an EF ECU), the engine tends to ping from 2500rpm up...
Issue is that I spend most of my time over 2500rpm... I haven't got a tune just yet though, but I find i've got more power on 95 than 98..
Old 31-12-2011, 07:44 AM   #5
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
On my NA EF 6cyl I have always used Magnatec 10w/40w
And always use BP 98 or Caltex 98 (not woolworths/Safeway)
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2011, 01:25 PM   #6
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
Penrite sin20 and bp98. Recently made the move from castrol edge 25-50w. Engine is happier with the penrite I feel.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2012, 09:32 PM   #7
Ford_The_Win
N/A EL I6 with 120,000 kays.
Fuel - 91 octane - whatever's cheaper, usually either APCO or Caltex, never BP, the local BP is rubbish.
Oil - Castrol GTX 15W40.
I noticed sweet fa difference in performance when I've filled up with 95 or 98 so I stick with good ole 91. When you have a stock automatic car that rarely sees any action past 2,000 rpm, it's a waste of money. Plus I'm a cheapskate.
2011 FG XR6 Sedan
Ford_The_Win is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2012, 01:43 PM   #8
Mad Drummer
EF XR6
Mad Drummer's Avatar
im just about to service with 15W40, im jus trying the burson brand, never used it before but told its not too bad, and if its cheap enough ill use BP 98 but usually 91
www.OzEcruisers.com.au
95 EF XR6:
5spd Manual, 3.45 LSD diff gears, JIM MOCK EXTRACTORS, 2 1/2" sports exhaust Short shifter, Pod filter in standard air box, 17 inch EL gt rims in gold.
Lowered all round with king springs and pedders supsenion
Mad Drummer is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2012, 07:01 PM   #9
BA-XT
2003 BA Falcon XT
BA-XT's Avatar
Used to use Penrite in my old Land Cruiser, but found it not to my liking in the BA. Mechanic put in Shell Helix HX7 AJ 10w-30 and it feels much smoother on idle, and has no tappet noise when cold.
Will be changed every 5,000km.
Plain old Woolies 91 Ron with a splash of Moreleys Upper cylinder lubricant each fill. Now returning less than 11L / 100km. Very happy!
2003 BA Ford Falcon XT
IMPCO LPG Vapour Injection.
DETAILING
Meguiar's NXT Car Wash
Collonite #845 Insulator Wax
Bowden's Own Happy Ending & Fully Slick
Chemtech CT-18 Truck Wash (Wheels & Chassis)
Bowden's Own Wheely Clean & Tyre Sheen
Bowden's Own Three Way Paint Decontamination Spray
OILS AND FILTERS
Nulon Full Synthetic 10w-40
Nulon Long Life Coolant
Ryco Oil & Air Filters
My Instagram Account: @ba_falcon2003
BA-XT is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2012, 07:39 AM   #10
LTDHO
The one and only
LTDHO's Avatar
how come 95?
I'd be asking 'How come 98'?
Have you got a few mod's on it or just like wasting 20cpl?
I run 95 in the XF 'cause i have to, pings without it, damn Leaded cars!
LTD was tuned on, and runs on only 98. It can run on 95 as longe as I am gental with the boost.
Tuned by CVE Performance
Old 17-01-2012, 10:02 PM   #11
staunchxr
STAUNCHXR
staunchxr's Avatar
Last service I used castrol gtx 15w 40 that was on special for $18 at the local supercrap and usually 95 or 98 bp / caltex just because we advanced the timing and the XR loves chewing the best bitches!
smashen the boost!!
staunchxr is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2012, 06:51 PM   #12
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Any 91 except BP in Bulla, that place sells recycled sewerage mixed with 10% ethanol I reckon.
15W-40 Nulon oil.
250,000km on the clock on my EL Fairmont Ghia.
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
Old 12-02-2012, 04:27 PM   #13
FLUTTA
FLUTTA's Avatar
Most of the time I fuel up with 98, only occasionally does it get fueled up with 95.
And 'Nulon Hi-Tech Fast Flowing Synthetic Engine Oil - 10W-40'
Runs like a dream for a car that's done 270,000ish KM's.
FLUTTA is offline   Reply With Quote Multi-Quote with this Post
