18-07-2012, 08:54 PM | #1 | ||
As title says traction control/dsc light is staying on on dash, can't turn it off or.on using button.
Just recently added a bov is this the cause? As i thought engine light may come on not the dsc light. had it on a scan tool and no codes. Any ideas?
Rapid yellow 05 BF XR6T ute
333.5RWKW |
18-07-2012, 09:17 PM | #2 | ||
Been known to happen if the sensor units on the wheel hubs get damaged or misaligned things like a collapsing/loose front bearing hub can cause it.
18-07-2012, 11:07 PM | #3 | |||
Could also be the hub issue, but normally 5th and 6th gears are locked out and the reverse interlock doesn't work. The trip computer would also show ---- instead of the normal display. Not to mention the grinding noise from the front end. |
19-07-2012, 08:10 PM | #4 | ||
RS shop's technician
car needs looking at using dealer diagnostics. scan tools will only read the basic codes that are stored.
BOV shouldnt cause any issues with the ABS system, only engine DTCS. i have had them throw up a TC light when the treads are very bad on the rear wheels but fine on the front as the wheels can skip but thats when they come on then go off once the ignition is cycled
Advertising removed |
19-07-2012, 11:01 PM | #5 | |||
FORD FOCUS Titanium Sedan with Sports Executive Pack in Midnight Sky GDI Going somewhere isn't why you drive, driving is why you go |
20-07-2012, 02:59 PM | #6 | ||
Nah only thing we have done is put the bov on.
333.5RWKW |
20-07-2012, 09:27 PM | #7 | |||
Thailand Specials
I smashed off the wires on one of my wheel speed sensors the day after I lowered the car, ABS and traction control light came on. |
20-07-2012, 09:31 PM | #8 | ||
Barra Turbo > V8
Yep my bet is wheels speed sensor. Seems a common issue with our cars.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
21-07-2012, 04:24 PM | #9 | ||
Check out the focustoc forum there is plenty of info their about the tc light.
Mine came on when i swapped the airtec ic back to std intercooler (reason to keep the car stock for a ford service) I didnt tighten up the cold side jubilee clamp, retightened clamp & all good after pulling the kam fuse to reset the ecm. |
31-07-2012, 06:24 PM | #10 | ||
and the problem that cause the traction light to come on was?
