Just purchased these;
http://www.ebay.com.au/itm/221142531...9#ht_500wt_922 For the princely sum of $295 Any hints on fitting them? |
Fiesta headlights are easy as, getting the DRL's to work on the other hand im not to sure
Mmmm....yeah, I thought as much.
I'm sure there is a way, and I'm relying on the greater Fiesta community to come to my rescue! |
Perhaps you can splice the DRLs into the first click of the headlight dial?
I would be careful with those lights too, in terms of legality. Whether the lamps are aligned properly, whether it's going to blind anyone, whether it's too bright or not. Last edited by Caydus; 25-10-2012 at 01:44 PM. |
It says they are plug and play.
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang GT 10A Grabber Blue Nite Pony Package. Due Aug 24. |
I will take them to the mechanic after instillation for beam alignment.
As far as I know, they will have to be wired so the DRL's switch off when the low beams are switched on for legality. I have found relay/wiring looms that will achieve that on the net, but they all seem to be UK based and not available to be shipped to OZ. The seller still hasn't shipped the lights. Hope I haven't been taken for the proverbial ride. |
how'd the lights go Pursya?
Only received them today.
Disappointingly Aus Post had abused the packages enough to break one of the tabs that a bolt goes through. lucky I have some special plastic glue, so now looks like all OK. Plugged one in and it works, but not like DRL's should. They only come on as parkers. There is however a set of three wires with a very small plug that I do not know where to plug in. I have written to the seller and the manufacturer for guidance. Will keep you posted and hopefully get some pics up. |
Looks great and great buy compared to the $899 they want for a new set. Did you manage to get the LEDs running correctly?
Waiting on a Canbus module from the UK.
Seller doesn't ship to OZ, so I'll have to use a reshipping agent. |
#12 | ||
Barra Turbo > V8
I nearly purchased a similar set for my XR5 but i was told that the light was no good at night. Wonder is the Fez ones are any better?
-2011 XR6 Turbo Ute -2022 Hyundai Tucson Highlander Diesel N Line |
I took it for a run last night. Low beams are fine. Will need to adjust the highs.
Warnings on the lights not to install HID's. bummer. |
#14 | |||
Thailand Specials
Also, did you have the factory halogen projector assemblies on your WT? |
#15 | ||
but he's got projectors now? it's saying to not install HIDs in the projectors methinks.
There are no projector lights offered for any WT fiestas from the factory. |
#16 | ||
The upgrades are projectors.
The standard WT's are not. |
#17 | |||
Thailand Specials
There are projectors out there designed for halogen and these are it and same with the factory upgrades. I was asking about his old WT assemblies because I was curious if they were projector ones, as I would have bought them off him ![]() |
