2008 BF Futura
Hey,
I have one on order right now (Haynes Manual), but I don't think I'll get it before I need to fix two things. I was wondering if someone could please scan the section on replacing the Water Pump and Replacing the auxiliary belt.. It's for a 2004 WP Mk6 Ford Fiesta 1.6 Petrol. Thanks in advance, Alan.
2008 BF Falcon Futura 2009 BF Falcon Wagon Dedicated LPG Previous Cars: 2003 BA Falcon Wagon Dedicated LPG 1999 Ford Fairlane Ghia XF Fairmont Ghia Escort MK2 RS2000 Replica |
I have a wp fiesta haynes manual here...according to the manual,no belt tensioner is fitted to the 1.6 litre Duratec engine as the belt used is the stretch fit type(just like a giant rubber band).The only way to remove the drive belt is to cut it.New,genuine Ford belts are supplied with several special plastic tools required to fit the new belt.To gain access to belt,there is a lower drive belt cover behind drivers side front wheel which must be removed(easy to do,just unclip power steering pipe and remove the 2 retaining screws,and you may also get better access to water pump by removing the rh side headlight.Water pump removal is pretty straight forward once you have the drive belt off.
