Old 21-08-2007, 12:13 PM   #1
Eddie Van Halen
It's 5150 Time !
Default Brake shudder in a Zetec?
Hi all,
Anyone have any issues with brake shudder in their Zetec?
Apologies if there's threads on this, I've done a search but couldn't come up with anything relevant.
I'm just noticing a slightly jumpier/bumpier ride when I'm coming to a slow stop in the car.
Cheers,
al
Eddie Van Halen is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2007, 01:08 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
Not an issue I have struck before Eddie. Maybe discs need re-machining? How long since the brakes were serviced?
Old 21-08-2007, 01:18 PM   #3
Eddie Van Halen
It's 5150 Time !
I picked it up in Feb 06 and it's done about 22,000 ks'....
It's only had its first service, the 15K one... so yeah, might have to take it back for them to take a look at it and then spin me whatever crap they will!
Old 21-08-2007, 03:42 PM   #4
BlackLS
Probably a rear wheel unbalanced. If only the steering shudders the fronts are unbalanced, if the whole car does its the rear. What I'm thinking is when you brake the rear has less weight on it, and the rear tyre wobbles the car around.
Old 21-08-2007, 03:51 PM   #5
More revs
An ABS transducer cable might have come off. Get Ford to check out the ABS.. Otherwise yes a badly warped rotor can do this but I havent heard of this being a problem on the Focus. Ive abused my brakes plenty - glowing and smoking but they havent warped or anything - a bit grooved is all..
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2007, 06:40 PM   #6
whippet_zetec
Supes
whippet_zetec's Avatar
LR Focus or LS??
I have an LR and no brake issues ever in 3 years...mind you only done 35,000kms in it
Yes I DO drive a Toyota
whippet_zetec is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2007, 08:10 PM   #7
Eddie Van Halen
It's 5150 Time !
Thanks all...
It's an LS. I'll get it checked out on the weekend.
Other than this, trouble-free motoring for the past year and a half (bang wood). Awesome little car.
Old 21-08-2007, 11:21 PM   #8
FOCUSonTHIS
FOCUSonTHIS's Avatar
I had brake shudder on my LR Focus....warped disc....thats what happens when you spray it at the car wash when the brakes are still hot
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 30-10-2007, 05:16 PM   #9
Eddie Van Halen
It's 5150 Time !
All,
Just thought I'd update you with my brake shudder issue on my Zetec.
Took it into Ford on Saturday and they machined the discs under warranty - they said that it's quite a normal occurance on these cars as well as BA's.
Car's back to driving beautifully!
Old 01-11-2007, 03:42 PM   #10
plee
plee's Avatar
My CL LS has brake shudder when braking from high speed, booked in for next week, I'm also getting squealing from the wheels when taking tight bends at anything other than crawling around the corner, tyres aren't bald at all though... any ideas?
Thanks
BF Fairmont Ghia 2006 - Lightning Strike
plee is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2007, 10:35 PM   #11
mattyW
I've had a problem with this on my 2004 LR a couple of times, once in Oct 2006 (35k I think) and again in oct 2007 (47k), just had the discs remachined and my mechanic told me that definately the discs will have to be replaced next time. I love my Focus but a $500 annual brake service, in addition to the standard service, seems to be the norm for me (I was warned by a friend who had the same thing happen with his but again he liked his focus).
Have not been happy with service by the Ford dealer though. I continued to take it there for the 10 months of warranty left when I bought it but their service was awful. They offered to "rotate" the tyres without checking balancing leading to 2 wasted return trips and $140 in rebalancing that was only finally sorted out when a different ford dealer put the tyres back the way they originally were (I've always been a little concerned by that?!)
Matt
mattyW is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2007, 12:48 AM   #12
BlackLS
yum
Thanks
Is it tyre noise or more metallic squeal? I'd check your tyre pressures.
DBA's seem good at helping cars prone with brake shudder to brake normally.. Also they are more than likely cheaper than OEM and offer way better braking.
2005 LS Focus LX
250,000kms.
Old 28-11-2007, 06:49 PM   #13
Eddie Van Halen
It's 5150 Time !
My braking is fine after they machines the discs.... but Im still getting a grinding noise when im reversing slowly out of the driveway.....
Old 04-12-2007, 02:01 PM   #14
plee
plee's Avatar
Had it checked, pressures were down a bit, they also rotated and rebalanced the tyres, together with machining disks, is all fine again now
