Old 12-04-2013, 10:11 PM   #1
speed d8r
Default Power windows
I have just started a power window upgrade in my ute and need some help with the wiring, I don't have power (12v) to the relay (pin 85), now I have a parts car which I'm using and when I traced it I found it comes out of the blue plug (back of fuse panel) which then goes to the BCM is this right or did I stuff up? If I'm right how do I get around it, I would like to use the fuse panel for the relay if I can?
Thanks
speed d8r is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2013, 02:15 PM   #2
Gaz
Got Ghia?
Gaz's Avatar
Default Re: Power windows
Traditionally Pin 85 is earth.
Colours according to manual (if you trust that!)
Power to pins 86 and 30 from 30amp C/B in fuse box.
Brown/pink wire to BCM from 85
Grey/yellow from 87 off to your power window switches
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2013, 08:16 PM   #3
speed d8r
Thanks Gav
Will need to check it out tomorrow
But if I run a wire to the BCM will I need to take it to ford to be reprogrammed?
Old 15-04-2013, 08:00 PM   #4
Gaz
Got Ghia?
Gaz's Avatar
I don't think you can just run a wire to the BEM, you'd need a BEM that has power window control.
In _theory_ you should just be able to earth pin 85 and the windows will work, but you won't get any of the controls the BEM offers, however I have not checked what the exact BEM funtions for the power windows is on the AU.
Old 16-04-2013, 08:13 AM   #5
speed d8r
I spoke to an auto electrician yesterday and he said the same, just earth it, so I have them working
