Old 02-05-2013, 08:36 AM   #1
PeterShaz
Default cluster for a ford fairmont au1
is there a positive and negative on bulbs for a cluster for a ford au1 series can anyone help me
PeterShaz is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2013, 01:43 PM   #2
rmack
rmack's Avatar
Default Re: cluster for a ford fairmont au1
They are not marked, as incandescent bulbs are not polarity consciousness
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2013, 03:35 PM   #3
PeterShaz
I replaced all bulbs and stillwont light up but where the climate control is that dims with the switch but the cluster wont
Old 02-05-2013, 05:48 PM   #4
rmack
rmack's Avatar
Did you use blubs or LED's (LED's are polarity consciousness and may need to be turned around to work)
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 02-05-2013, 06:14 PM   #5
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
What can sometimes happen is that those aftermarket bulbs are half a millimeter out and the metal contacts are not touching from the circuit board to the light bulb.
You will have to take the panel out and put it on the bench. Good idea to check you have battery voltage and ground on the two metal contacts either with a multimeter or testlight.
I cut two little pieces of aluminium foil and fold them into the shape of the metal contacts so that they are around 1mm in thickness. Then simply place on the back of those metal contacts on the circuit board and screw the bulb in over the top. Everything then should be locked in tight.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
