Old 13-07-2014, 05:13 PM   #1
Gregoryg
Default Fuel type 91, 95, 98 premium
Hi All
I have a focus sport 2014 and the sales person told me to use 91 but in the manual it says to use premium 98. so what should I be using or does it not matter
Gregoryg is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2014, 05:16 PM   #2
Top_Ghia
Technical Contributor: For members who share their technical expertise. - Issue reason: has been consistently providing good technical advice etc. to AFF members, by having the vast technical knowledge he has with the various Ford products. A valuable AFF member
What does it say on the fuel filler?
Top_Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2014, 07:35 PM   #3
marg99
Default Re: Fuel type 91, 95, 98 premium
matters
Old 13-07-2014, 09:21 PM   #4
Gregoryg
all it says is unleaded only and suitable E10
Old 13-07-2014, 09:52 PM   #5
Top_Ghia
91 is fine. It would say premium only or minimum 95 if it needed it.
There's only a couple of fords that spec premium as a minimum. Focus isn't one of them. Even the ST uses 91.
Old 15-07-2014, 08:47 AM   #6
RedChris
My Mark 1 Trend 2.0 will officially run on any of these but 95 was the recommended RON when I bought and that's what I have been using.
RedChris is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2014, 11:21 PM   #7
In Focus
My old auto LV used to ping in 3rd gear with 91. 95 was fine, 98 even better. It probably depends on whether you intend to keep it a long time and/or get the most responsiveness out of the engine.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
In Focus is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2014, 12:52 PM   #8
marg99
the extra costs of 98 fuels makes the cost per 100klm significantly dearer, Thats the reason I steer clear of the VW trubo petrol models they need 98 octance
Old 21-07-2014, 02:00 PM   #9
dan-
i have only ever used 91 in my 2.0l trend. unless your car needs 98 to avoid detonation, i don't think the 98 stuff is worth the difference.
dan- is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 11:27 PM   #10
SMP
Quoting from the Owner's manual of my LW Focus MkII; Page 106, bottom left corner:
"The engine in your Focus has been optimised for operation on premium unleaded fuel (95 RON or higher). For all petrol variants it is also safe to operate the engine on standard unleaded fuel (91 RON minimum), however if you choose to do so, you may notice some minor loss of performance, economy and increased engine noise."
Personally, I've gone away from 91 because there was perceptible difference with premium fuel. Could be a psychological thing, but I like to pamper my car.
SMP is offline   Reply With Quote Multi-Quote with this Post
