20-06-2015, 11:20 PM | #1 | ||
the problem i have is when u switch air direction from dash vents to windscreen vents using the air distrubution switch it will not switch over to windscreen vents for demisting all other settings work has anyone had this happen .usually when switching over u can hear the heater vents open and close redirecting air to and back .has anyone had this problem and what is causing this .thanks all
21-06-2015, 07:10 AM | #2 | ||
Chairman & Administrator
Almost certainly one of the vacuum controllers has become dislodged or failed.
Cheers Russ
Observatio Facta Rotae
21-06-2015, 12:21 PM | #3 | ||
22-06-2015, 07:41 PM | #5 | |||
26-06-2015, 07:28 PM | #6 | ||
you were right heater controller switch but had to buy the whole facia panel with all the switches inc clock cig lighter and vents $80 wrecker wouldnt separate.was that a fair price?
27-06-2015, 08:36 AM | #7 | ||
Given the heater controller switch is a $90 part from Ford (assuming they are still available) then yes.
Cheers Russ
27-06-2015, 03:27 PM | #8 | ||
