Does the brand of coolant used matter? I've got a bottle of Calibre Coolant which I bought to flush my fathers car with (I cheaped out alright. It was half the price and his cars falling apart anyway) and now I've just found out a radiator hose on my Fairlane's torn so I'm going to have to drain and fill that up too.
Would it be allgood to use the Calibre coolant to refill the lane up or should I waltz back into the store and buy a proper bottle of Nulon like I usually do? Hopefully supercheap will accept a return and allow me to get the Nulon stuff instead
Project/Fun Car - BA MkII Fairlane Ghia
Daily Driver - Volvo V50 2.4 "If in doubt, flat out" - Colin McRae "Horsepower is how fast you hit the wall. Torque is how far you take the wall with you" "Cheap, fast and reliable. Pick Two" |
#2 | |||
Performance Inc.
The brand of coolant probably doesn't matter as much as the chemical composition. For instance in my cars the Suby and Lotus use a different chemical based coolant (red stuff) to the Ford (green stuff) due to the composition of the metals and rubbers the coolant runs through.
I know it sounds pedantic but its about chemical reactions with different materials.
In The Garage... ![]() FPV Super Pursuit Build no 0080/91 Lotus Exige S/C S240 Kart Hasse Chassis 100J Power Quote:
2 users like this post: |
You need to check if it is "ready to use" or "concentrate" that you are buying
Ready to use means you just bought 90% water
1940 Ford Deluxe Hotrod 1956 Ford Mainline 1958 Ford Customline 2002 Ford Explorer I only drive V8's |
#4 | |||
![]() Join Date: Oct 2006
regards Blue |
HSV - I just ate one!
Some ready to use coolants are also a straight up corrosion inhibitor with no anti freeze/anti boil ability, ie: no glycol
Well I just went back and swapped it for some Nulon Long Life Green. Both were concentrates yea. Ended up deciding I might as well do it properly instead of half arsing it. Considering replacing the thermostat at the same time. Thoughts?
Some years ago a mates Nissan Patrol was starting to overheat so we whipped the radiator out and hung around while the radiator shop took the top tank off. The top was full of jelly caused by topping up the system with a different brand coolant.
Buying cheap coolant is false economy.
1976 F100 351c traytop tipper. 2019 Mercedes V250 van. |
Does brand matter ? for me its the perceived quality of the product , i like to think it has the required ingredients to inhibit corrosion/electrolysis and keep the coolant from boiling/freezing in adverse conditions , my henry is 16 years old with the original head gasket/unopened, so i must be doing something right with my cooling system ingredients ......either that or its just a grouse old donk
Something else to remember is that the 1 litre bottles of concentrate may well have enough corrosion inhibitor additives to treat a 12-15L cooling system, but the glycol content when watered down will be like taking a whizz in the ocean.....
#11 | ||||
As the say here: http://www.noranews.org/?page=AntifreezeInfo Quote:
Purse glycol unlike a water glycol mix also has a freezing point not lower than water: ![]() While ethylene glycol has many advantages, it does not transfer heat as well as clean water. Excessive concentrations will cause a significant elevation of engine operating temperature and cooling system failure. Using just concentrate or levels above 70% will likely result in a catastrophic failure and perhaps a blown head gasket. It's the water in the mix that does most of the actual cooling. The coolant additive is there to prevent freezing, inhibit corrosion and lubricate the water pump bearing. See https://hellafunctional.com/?p=629 and the articles referenced at the foot of that page.
regards Blue Last edited by aussiblue; 22-01-2017 at 02:25 PM. |
#12 | ||
Call me dirt... Joe Dirt
Have and always will use Nulon only.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
What I was saying is that a single one litre of concentate quite often labelled as "makes up to 15 litres of coolant" will have insufficient glycol to treat a cooling system capacity of 10-15 litres, because whatever you do, even 1 litre of pure glycol cannot possibly make the minimum of 33% when mixed with enough water to fill an average cars cooling system.
#14 | ||
B1 - J & D Services
![]() Join Date: Aug 2005
Nulon make Calibre coolant.
Mr. Brett Johnstone. ![]() 2002 Ford Laser 2000 Ford Falcon Wagon Egas 1999 Subaru Imprezza Sportwagon 1998 Holden Suburban 2500 1995 Land Rover Discovery TDI 1994 XG XR6 Longreach 1983 Holden Rodeo 1982 ZK Fairlane 302 six seater 1975 Datsun 120Y wagon 1970 MG Midget 1967 Rover 2000TC Soon: Model T. |
#15 | |||
If you mix different brands you do run the risk of electrolysis, which will lead to a hole in your radiator, or worse still in one of the engine water jackets.
#16 | |||
regards Blue |
#17 | ||||
#18 | ||
Doesnt matter who makes it, it will be made to supercraps specifications.
#19 | ||
B1 - J & D Services
What an Australian standard???
#20 | ||
I use Nulon on mine.
Personal preference and brand name that I would entrust with Calibre brand for a falling apart car is fine I'm sure prob outlast the car Sent via my ASUS ZE551ML
Before - ED Falcon Futura (sold) EL XR6 (R.I.P.) VX SS (R.I.P) VE Berlina |
#21 | ||
FPRJET
interesting a BMW mechanic friend of mine worked for ford & holden before BMW I told him I just bought some ford coolant and he said its to acidic.. He actually recommended Repco.....
Proud to own a FORD and sick of the constant bagging. You don`t like it, go buy a Holden, you`ll be back soon. ![]() |
