Anybody used one of these that they would recommend?
From what I have seen, they seem to fall into the following categories:
I'd also like to know the best way to test an alternator. (Without buying an $800 tester.) I've tried using a multi-meter, but that can only measure voltage, and is usually ambiguous. NB: Please don't suggest "go to an auto electrician," as obviously I would already have done that if so inclined. |
You only need a multimeter, knowledge of correct voltages, and some intelligence.
To load test an alternator, monitor the voltage while you turn heavy consumers on - headlights + high beam (there's 20-30A right there), rear demister, aircon (to kick in the thermo fan). If the volts drop below about 12.5, then the alternator can't keep up. Be careful of "smart charge" cars that can throw the figures out - although usually after a starting cycle they'll charge at 14-14.5V for 5 minutes or so. If you want to actually "dyno test" an alternator & find out what actual amperage it's putting out, you really need a carbon pile. Most batteries can be tested by watching the voltage when you crank the car. A good rule of thumb is double figures - ie if it stays above 10V cranking it's still reasonable. A healthy battery will normally sustain high 10v to 11v readings while cranking. |
5 users like this post: |
![]() Join Date: Jan 2005
For basic in car tests I use a multimeter.
Ideally you will see 13.8 to 14.2 volts from the alternator. Start the car. Put the voltmeter across the battery terminals, measure the voltage. The turn on accessories likes headlights, ac, demister etc to create electrical load and measure again. You will generally see the volts lift slightly as the engine RPMs increase off idle. For basic battery test you can do the same without the engine running. Check voltage with accessories and lights on. They are just basic tests but show up if you have a problem 99% of the time.
I love Holdens.... |
I've seen alternators register adequate voltage, and still be unable to charge a battery.
The problem is always in the grey areas. A multimeter can tell you if the battery or alternator is completely cactus, but when neither is, its hard to sus out. And, to make matters worse, it could be neither. Could be a current drain. |
A tool called a hydrometer was an easy way to check for a dead cell in a multi cell lead acid battery, I still use one on my deep cycle batteries, however my car batteries are now all sealed making specific gravity tests impossible. I found the voltage tests already mentioned to be the most useful but if I deem it necessary to externally charge the battery I watch the amp meter for normal behavior, it should start out high and fairly rapidly decrease as the batteries resistance increases.
#6 | |||
I can be sometimes hard to pick up an alternator fault and I have seen some where the alternator tested OK but the regulator dropped output when hot.
![]() Join Date: Oct 2006
The cheap battery load testers like this http://www.ebay.com.au/itm/BATTERY-L...IAAOSw9eVXVl6m work fine for load testing and the scale on the gauge is calibrated to show the reading for different CCA batteries. They are really only useful when a battery is not holding it's charge and you want to know if the battery is dying or the charging system is at fault; but in those situations it is extremely useful. The carbon pile ones like this don't tell much more (essentially just a current reading) http://www.ebay.com.au/itm/Battery-L...UAAOSwtJZXW3dy
A clamp on AC/DC multimeter is useful as it allows you to more readily test the alternator output by placing the clamp around it's output wire to measure amps. A clamp on meter also allows you to more readily track parasitic drain by moving the clamp along the wiring harnesses from the battery to the drain source. Like this http://www.ebay.com.au/itm/Pro-Serie...EAAOSwv0tVXPP7 Watch out and read the spec carefully before buying a clamp on meter as many like this http://www.ebay.com.au/itm/New-Clamp...kAAOxyf~hRzZ0n while describing themselves as AC/DC clamp on meters, only read AC amp with the clamp function. Jaycar and Altronics both sell suitable clamp on meters such as https://www.jaycar.com.au/400a-ac-dc...meter/p/QM1563 and http://www.altronics.com.au/p/q0968-...c-clamp-meter/
regards Blue Last edited by aussiblue; 12-02-2017 at 12:34 PM. |
Oh and Supercheap have a AC/DC clamp on meter too: http://www.supercheapauto.com.au/Pro...Digital/387596 There cheaper one is AC only.
regards Blue |
The good, bad and fugly
![]() Join Date: Feb 2016
Blue has offered some good advice.
Using a DC clamp meter is a very good way to judge alternator performance. Clamp it on the cable that connects the alternator to the battery and switch everything on that uses power from the battery such as headlights on high beam, a/c on high fan, demister etc With the engine at around 1500RPM, looking at the clamp meter display, you should be able to see a reasonable amount of current being produced by the alternator up to it's maximum current rating. The Voltage at the battery should be 14- 14.5V during this test.
Time was on my side! |
#10 | |||
Experienced Member
Guys testing of batteries & charging system require various methods, equipment & knowledge/experience |
#11 | |||
regards Blue |
#12 | ||
Hydrometers effectively only measure the acid concentration. A an old cactus battery that is fully charged will still read as good.
I'm curious as to how DC clamp ons work? I thought only AC would generate the requisite field? |
#13 | |||
If you want to buy a tong meter you should invest in a decent one.
#14 | ||
around the place
just do the old test where you drop the big flat head screwdriver that comes in the stanley kits across the battery terminals, if you get big sparks and the screwdriver partially melts then battery is fine...
GPS Tracker for your vehicle - PM me for info |
3 users like this post: |
#15 | ||||
regards Blue |
