Old 08-08-2019, 08:24 AM   #1
ARL111
Exclamation AU Temp sensor grommet
Urgent help required, I was swapping out the temp sensor for my AU coolant tank and the grommet for the temp sensor disintegrated and I can't find one in NZ.
I dont really want to buy a new coolant tank just for the grommet.
can anyone help me please.
Thanks in advance.
Jason.
ARL111 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2019, 12:38 PM   #2
macman
macman's Avatar
Default Re: AU Temp sensor grommet
I assume you're referring to the level-low sensor in the high-series coolant tanks.
From past experience, the replacement sensor comes with the grommet (when purchased new as a spare part anyway).
But you can buy the grommet separately (on ebay or your local parts supplier) - https://www.ebay.com.au/itm/GENUINE-...L/300566115155
If you need the car driving and can't wait for postage for the above item, you could try a wrecker - even if you get a tank without the sensor, you can still use it, just obviously can't connect the sensor. BUT it's only a low-level warning sensor so AFAIK it won't affect drivability/safety as long as you visually make sure your coolant isn't low (dash may still alert you the level is low).
macman is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2019, 03:36 PM   #3
Bill M
Bill M's Avatar
Is this it?
https://www.ebay.com.au/itm/GENUINE-...frcectupt=true
AUII XR6 VCT ute
20 years and still going strong!
Bill M is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2019, 03:38 PM   #4
ARL111
Originally Posted by Bill M View Post
Yes it is thanks. Just ordered some
Old 08-08-2019, 03:38 PM   #5
ARL111
Thank you very much, just ordered two.
Old 08-08-2019, 03:46 PM   #6
Bill M
Bill M's Avatar
Oops! I think macman had it right first. I didn't see his post.
Good luck with the fix ARL111.
cheers
Bill
AUII XR6 VCT ute
