Old 08-11-2019, 11:15 AM   #1
fordmondeomk4
Default Purge diesel system
Hey all, what have people used/done to bleed the diesel system on an MA Mondeo 2008 tdci? I've pumped and pumped and it seems there is continually a pocket of air forming around the diesel pump feed line. So I might need some form of stronger gear pump, as the pump I've got might not be strong enough to suck through the pump return line.
Also I have cracked the nut on the injector and cranked the motor, so I believe that's how you bleed the high pressure side?
Had a problem where the car cut out with no codes. I swapped the diesel filter, injectors and pump with new and known working units. I made sure I pumped diesel back through the feed line so the whole feed line and filter pot is full of diesel.
Thing still won't start and not showing any codes. Definately half a tank of diesel in there, I've added a good 20L to it.
Thanks.
fordmondeomk4 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2019, 12:03 PM   #2
11ford11
Default Re: Purge diesel system
Try spraying aero start or wd40 ( anything with no.2 on red label on side of can) into air intake
You may need to spray( with in reason ) long enough to eliminate air from system
Why did it cut out ??
Does fuel pump work. Have you checked fuses / relays etc. Did it run out of fuel . Does immobiliser light go out. Does it have a fuel shut off switch they may have tripped ref. owner’s manual.
11ford11 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2019, 12:31 PM   #3
fordmondeomk4
Thanks for your reply.
The fuel pump and injectors are from another known working car.
I don't think it run out of fuel, it was showing a good amount left, however.... I did 808kms from the tank (normally easily get 850km before I have to fill). It was run out of fuel symptoms though... Pulled off freeway, put my foot down normally from the lights, seemed to hesitate a little, kept driving, did it again, about 1km later, thought this is odd, gave it some stick up a hill and she cut out and wouldn't start again.
Check fuses, relays by swapping them , owners manual... I think these things just might be a bastard to bleed the air out properly.
Old 08-11-2019, 12:40 PM   #4
11ford11
Try the spray and see what happens it should at least fire on it
Old 08-11-2019, 12:58 PM   #5
fordmondeomk4
I'll get some today and see how I go.
Old 11-11-2019, 06:17 PM   #6
bundybear75
bundybear75's Avatar
Fuel injectors on a common rail need to be coded into the computer. It may not recognise they are there. Even swapping two around will cause the car not to run
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2019, 11:50 PM   #7
happy1
Hi,
Where have you heard this?
The reason for the coding is to get the calibration right, in order to eliminate the build tolerances in the delivery volumes for each individual injector.
On vehicles like Ranger PJ/PK and Territory SZ you can easily swap out injectors and not notice anything (still running fine), but you may see differences during a smoke test or dyno run.
Back to the Mondeo issues, Have you replaced the feeder pump?
Cheers,
'11 FG Turbo
'08 Territory SY RWD
And some non-fords: E90 M3 build, '07 Rocket III,
happy1 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2019, 10:28 PM   #8
cobrin
Challenge Accepted!
cobrin's Avatar
Thanks.
I use a
vacuum
a large jar with tin lid
suitable vacuum hose for the fuel return line
make a hole in the jar lid for the vacuum hose to cover.
make a hole for the hose that's going to fit in the fuel return line but engine side.
screw lid onto the jar.
now turn on the vac and place the hose over the hole in the jar lid. This will keep a vacuum in the jar. The hose connected to the fuel return line should now start to suck fuel from the tank-filter-engine-injectors all the way to the return line and into your jar. It took about half a (Large as in 3L+) jar of fuel before the fuel stream was clear and without air bubbles. Only when it were constant fuel and nothing else did I then turn it off connect the return line to the correct fitting and start the engine and it stumbled for only a few seconds before it took off under it's own steam from the starter motor.
Now return the fuel in the Jar back to the tank. The hoses I used that happened to be good for the job were from a $20 SCA hand pump that was an epic fail, thank god for the hoses though.
Undecided replacement...
[SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD]
cobrin is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2019, 06:20 AM   #9
GTMOND
Originally Posted by cobrin View Post
I use a
vacuum
^^^^ That's exactly how I did mine, when I had my MA Mondeo.
GTMOND is offline   Reply With Quote Multi-Quote with this Post
