Old 28-03-2020, 08:09 PM   #1
Smoke Pursuit
Default Replacing power antenna on Auiii xr6
Hey guys,
I have just bought my dream AU3 Xr6 VCT. A very tidy one owner car in blueprint. Working on fixing a few issues. One is the power antenna. It goes up and down but doesn’t go down the full way. Can you buy a replacement? Any tips / ideas cheers!
Brent
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2020, 09:15 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Replacing power antenna on Auiii xr6
Hi. It could be 2 things, a bent mast, that you can check for by setting the antenna to half way and seeing if each section slides into the one below it by manually pushing and pulling the sections up and down or it has had a broken cable inside the mast and someone has fitted a new mast & cable without taking out the broken 3 inch bit in the bottom of the antenna. This lets the new mast retract until there is no room for the cable to store in the housing and the antenna retracts no further. If it is a bent mast ,Aerpro do a replacement mast & cable (AP12 Mast and cable) that should fit. The complete antenna (AP3) is no longer available from aerpro. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2020, 10:37 PM   #3
Smoke Pursuit
Thanks a lot mate. Looks like I’ll be pulling it apart!
