Hi all,
With the current times we live in, it looks like my Focus ST will be doing a lot of sitting around. Usually used on weekends only. So I am thinking I may need to keep the battery charged to avoid killing the battery and also experiencing weird electrical gremlins low batteries can bring on. Two questions, 1) recommended chargers, will a cheapie suffice as long as it has a trickle/maintenance setting. Something from repco or supercheap? 2) can I just connect it without disconnecting the battery from the car? Thanks in advance.
2016 Mazda 3 SP25 GT 2019 Hyundai i30 Active. |
It’s hard to go wrong with Cetec chargers. Repco often have them on sale, and for maintenance charging, you only need one of the smaller ones.
Ive got several for all my cars - some of which only do 500 miles per year - along with a 15 amp monster from SuperCheap. It’s currently charging up my totally flat battery from my Ranger. At 15 amps, it will probably run overnight. Cetec chargers will come with a tail that connects to the battery. Just plug in the charger, and you’re good. |
![]() Join Date: Dec 2004
C-Tek 10 amp would be my choice … I have both 10 and 15 C-Tek . The reason I say 10 is for Optima dry cell , 10 amp max recommended and for me the 10 amp has the quick connect that the 15 doesn't
Thailand Specials
If it has a flooded lead acid battery, don't let it sit on float charging for weeks on end, it evaporates the electrolyte solution inside the battery and can lead to a battery explosion next time you try start the car - Worksafe Victoria released a really good safety notice on this for flooded lead acid batteries used on diesel generators as they experience identical conditions as weekenders sitting on float charging for weeks on end:
https://www.google.com/url?sa=t&sour...ys0mmrTMul8lEY Charge it up, then turn the charger off, then turn it on again in another two weeks then off again. |
6 users like this post: |
i just use something like this...
https://www.ebay.com.au/itm/10W-12V-...a5b0095835ba1d You might have to lengthen the lead so you can get It near a Window or outside somewhere. |
At the risk of stirring up the snake oil argument, maybe some fuel stabiliser as well...
#7 | |||
3 users like this post: |
2 users like this post: |
The good, bad and fugly
![]() Join Date: Feb 2016
C Tek chargers are highly overpriced. If you have deep pockets, buy a C Tek. If you have any value for money sense, look at the various multi stage chargers available online for a fraction of the cost.
Car batteries are designed fol charging and discharging at high rates. For this reason its important to buy a charger with a maintenance cycle suitable for your battery. Some are used to charge deep cycle, absorbed glass mat (AGM) or gel batteries, these are mostly different from the average car battery. In short, make sure that the details or description of the charger you choose is specifically designed to be used for car battery charging. |
Thailand Specials
I used to use two in my workshop, I had the 21A version of this charger below:
https://www.supercheapauto.com.au/p/...er/292792.html and a 50A workshop charger for bigger stuff with standby power etc. The one in that link above would be fine for you at 8A and its cheap and works. |
Hi All,
Thank you for all your replies. I am still researching to find a decently priced charger. Unfortunately a solar set up as recommended wont work in my garage, no where near enough sun. CTEK do seem to be quite expensive. Fuel Stabiliser is something i was also thinking about. And franco unfortunately the charger you suggested at supercheap (which i was ready to jump at) does not seem to be available, nor at that great price sadly. The other Projecta chargers i could find seem to be pretty expensive starting at $160 + for 5A. I have found this which seems to be similar https://www.supercheapauto.com.au/p/...start=12&sz=60 The joy of cars... parking them up still requires money ![]() Thanks again!
#12 | ||
I use a Projecta trickle charger and have had it continuously connected to my GT Falcon and now my Mustang for some years with no problem. It's 1.6 amps from memory, is fused, and I have never had a problem with it. I also have a newer Projecta which can be switched from 1 amp to four amps , again fused and both go into float mode when full charge has been attained. Half the price of Ctek and just as good.
GT450 |
RPO 77
I have the projecta franco linked above - best bang for your buck going
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced? A: It is over priced - just like all the other falcon coupes for sale!! ![]() ![]() |
#14 | ||
Im planning to head to supercheap today, see what they have. Looks to be unavailable going off the website.
#15 | |||
Experienced Member
Weekend usage will be sufficient to keep your battery, engine & rest of your vehicles running gear in good running order, wasting your time imo unless the vehicle is going to parked up for a few months.. |
#16 | ||
That is the issue. It is usually used on weekends. But right now, it’s not. Not a lot of places to go right now
#17 | |||
Experienced Member
Even a brief run to shops for essential goods will do it good, just a suggestion! |
#18 | |||
BLUE OVAL INC.
I cut the alligator clamps off and soldered an Anderson plug on and just hook it straight into the campers wiring, brings the battery back to 100% in under 24hrs and keeps it there ready to go again. |
#19 | |||
BLUE OVAL INC.
My Mother hasn't been using her Rav4 much due to staying isolated, last week we used it to do some running around and whilst it started, it was sluggish, a few days later we went to move it out of her carport and it was dead flat, put my charger on it (same as Franco linked) and it came back up. This battery is only 12 months old so not old. |
#20 | ||
Peter Car
Highly recommend the ctek. You get what you pay for.
#21 | ||
Ended up with a repco charger for $120. 9 stage, 8amp. May not be the best brands but I felt it was good value and will do what I needed it to.
In relation to running the car for half an hour, there are two issues here. 1) being it will not charge the battery all that well. 2) this a direct injected motor, which from what I’ve read, extended periods of nothing but idling will just clog the thing up and lead to engine damage down the track. People with Focus STs who have done this Have ended up with major engine issues due to carboned up valves. I’m not a mechanic but I’d rather take it for a drive once a month to the shop, with a battery charger on it weekly, than start it once a week to idle. Thank you all for the suggestions. Hopefully it will help others down the track as well.
2016 Mazda 3 SP25 GT 2019 Hyundai i30 Active. Last edited by fiestaz; 14-04-2020 at 04:40 PM. |
#22 | |||
Experienced Member
It will never fully charge a battery but will keep it in good condition, did this years ago when I had my commodore project which sat in my garage for four years. Who ever says an alternator does not charge while engine idling is dreaming, now I will wait for someone to flame me for this comment. Cheers. |
#23 | ||
#24 | |||
If this wasn't the case, there would be a lot of flat batteries in traffic jams etc. |
#25 | |||
BLUE OVAL INC.
#26 | ||
Cabover nut
In a 2 stroke Detroit diesel the alternator will NOT provide a charge while the engine is idling. There I said it.
#27 | ||||
Experienced Member
I should have mentioned in my other post increasing the revs up and down at times with the engine will help for charging and running of engine. Quote:
My comment was intended for most common passenger car alternators. Last edited by Itsme; 14-04-2020 at 08:53 PM. |
#28 | ||
FAWD - No Boundaries
![]() Join Date: Jun 2010
I have a couple cars that get occasional use.. I just remove the earth cable and the batteries stay good for months.
Yes... I have to reset the clock etc... but that just takes a couple minutes, so no biggy ! I pop the bonnet first... then get out and lock the car... then disconnect the earth and close the bonnet. To get in I just use the key in the door lock (the old school way ![]() D
View My Build thread 22 DJR Shell V-Power Mustang Eskymobile (my first EV) 07 BF2 AWD Falcon Wagon (Daily driver) 04 BA Falcon 1Tonner Ute (New Project) 03 BA Falcon Wagon (Spare) 98 NL Fairlane Ghia V8 (Weekend cruiser) 70 VG paddock racer (Cain it til it breaks.. fix it.. Cain it all over again !)
#29 | |||
You had to give 'em a bit of a Thongful to get the old Fashioned regulator to kick in.. @ Officemanager, they're usually a Geardriven Leece Neville Alternator.. |
#30 | ||
Looking for clues...
Supporting Franco's overcharging warning, I left my Sierra plugged up to a battery charger too long...
![]() It scared the crap out of me when I turned the ignition, and thought the IRA had come to visit.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
5 users like this post: |
