Old 02-09-2007, 05:54 PM   #1
josh_hartman
Default Easy Way To Change Leads?
Does anyone know a easy way to change the spark plug leads? It looks like a pain in the ***
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2007, 06:14 PM   #2
FGII-XR6
FGII-XR6's Avatar
not really just take the airbox out and you can reach the coil pac. Piece of pi$$
Old 02-09-2007, 06:24 PM   #3
Jokular
Jokular's Avatar
Yeah thats about it unless you have access to a hoist.
Should be the easiest thing to replace in a car but not on an au.
Jokular is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2007, 06:30 PM   #4
The Monty
Just slidin'
The Monty's Avatar
Just use your fingers and feel your way around. One plug at a time, and take out the airbox. And make sure the car is cool, I didnt learn the first time, so have done it twice while its hot, and by jove it gets hot.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 02-09-2007, 06:31 PM   #5
Jokular
Jokular's Avatar
It is..
On a hoist is the easiest.
Otherwise try this link
http://www.fordforums.com.au/showthr...t=change+leads
Old 02-09-2007, 09:48 PM   #6
sly
Sly like a G6
sly's Avatar
I found the best access to the coil pack is obtained with the head removed...
Sleeper, anyone?
Old 03-09-2007, 12:47 AM   #7
FGII-XR6
FGII-XR6's Avatar
yes and we are all going to rip our heads off to change the leads :
Old 03-09-2007, 01:16 AM   #8
TwistedEL
TwistedEL's Avatar
Get someone with long arms around to do it for you... as everyone has said, take the snorkel & airbox out and it is very easy.
Or if you want to do it the hard way, remove the head, lol.
Old 03-09-2007, 09:06 AM   #9
Robe
D'oh! Why didn't I think of taking the air box out? That would have been so much easier than climbing under the car six times. :togo:
Rob Ewart
Bog standard silver BF Wagon, except for the Elvis doll , on gas.
Victorian Rock'n'Roll Dance Association
www.VRRDA.com.au
2015 Victorian Rock'n'Roll Dance State Championships
23 May 2015, Furlan Club, Thornbury
Robe is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 09:20 AM   #10
StealthAu
I just remove the snorkel, can just reach the ones at the back
Old 03-09-2007, 11:22 PM   #11
sly
Sly like a G6
sly's Avatar
Derrrrr, I took advantage of having the head off to finally do something with the pack of spiral-wound leads I'd had on the shelf for 6 months.
Mind you if I S/C it I won't have an airbox to remove... will have to remove blower instead :. Must remember to change leads when installing.
Sleeper, anyone?
Old 03-09-2007, 11:33 PM   #12
FGII-XR6
FGII-XR6's Avatar
if i were puting in a blower i'd move the coil for better access
Old 04-09-2007, 11:03 PM   #13
sly
Sly like a G6
sly's Avatar
Anyone around Maitland you'd trust to hack the loom to do so?
Sleeper, anyone?
Old 04-09-2007, 11:20 PM   #14
FGII-XR6
FGII-XR6's Avatar
the auto electrician in Villa st east maitland is good and he's not a rip off
hanks auto electrics 19 villa st cnr of mill st (near the old pine doctor) 4933 7483
Old 05-09-2007, 05:56 AM   #15
au2sw
Blown 5L coming
au2sw's Avatar
lucky theres an "n" in that name....HAKS auto electrics
i find the easiest way is to number the leads to corrispond with the cylinder....ie 1-6, before pulling them off. then lay them on the ground in order of shortest to longest and lay the new ones out the same next to the old ones so the same sizes are next to each other. you may find that the lenghts vary from old to new, but as long as they are close in length, this isnt a problem. the coil pack is numbered (from front to back) 1-3 against the block, 6-4 closest to the airbox. as stated by everyone, remove the snorkle and airbox for the best access. dont know about using a hoist......by the time you have the car set up on it, youd have had the job just about done on the ground.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 08:43 AM   #16
StealthAu
No real need to number the leads, I've used a few different brands and all of them have the numbers marked on them.
Old 05-09-2007, 04:30 PM   #17
FGII-XR6
FGII-XR6's Avatar
the bit about the auto elec was regarding moving the coil before a blower is fitted not replacing leads. as stockoau said most leads are numbered now to make it fool proof ( b ut not idiot proof )
Old 05-09-2007, 07:36 PM   #18
sly
Sly like a G6
sly's Avatar
I put a set of Eagle spiral-wound leads on & had to number them myself.
Sleeper, anyone?
Old 05-09-2007, 08:11 PM   #19
au2sw
Blown 5L coming
au2sw's Avatar
we fit eagle and ICE leads specifically packaged for different vehicles, but they arent numbered. thats why i mentioned numbering them. if the leads are already numbered, thats an added bonus and cuts about 10 minutes worth of work out
Old 05-09-2007, 08:21 PM   #20
TwistedEL
TwistedEL's Avatar
If you just change them one at a time you don't need to number them and you can't put the wrong lead on the wrong terminal
Old 05-09-2007, 08:39 PM   #21
sly
Sly like a G6
sly's Avatar
Depends what else you are doing at the time. I was changing my head & took advantage of the clear access to the coil pack to change the leads. It suited me to pull them all off first as I could see the terminals. That won't normally be the case, but I'm used to being abnormal... :
Sleeper, anyone?
Old 06-09-2007, 11:21 AM   #22
S3SR
S3SR's Avatar
easiest way is remove airbox
either wait till car is cold or cover that heater pipe with alot of stuff...it gets damn hot..enough to blister a couple layers of skin
then pull on lead out, if you dont have the numbered lead set, just get one that is roughly the same length, replace that lead and so on until its all done....
i found it easier to do the leads at the back first, but having big hands doesnt help at all
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 08:33 PM   #23
irext
I'd rather be Fishing.
I've done mine twice! The second time cause I didn't push the lead firmly home on one spark plug and it literally burnt the end off the lead! Give them a good hard push until they snap onto the plug.
irext is offline   Reply With Quote Multi-Quote with this Post
