Old 13-06-2005, 10:00 AM   #1
5speedeb
now with 3.73 lsd
Default changing locks
what a great day
woke to find my car had been broken into took my sub amps deck
anyway drivers door lock is stuffed does anyone know how to change it and can i swap with the passenger side? by the way its an ea
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2005, 02:37 PM   #2
John_LS1
i would upgrade to the Tibbe locks being EA. to put them in you need to pull the doortrim off undo the door handle and and then undo the clip[ and the barrel will come out.
i have a full set off tibbe locks and key if your interested ;)
Old 13-06-2005, 03:31 PM   #3
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
if you are going to do a tibbe mod, be aware to do the ignition you will need a tibbe version of the bit that clamps to the steering column..
how exactly they get in?
worn locks?
cheers...
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2005, 03:44 PM   #4
John_LS1
i have the whole colomn for it.
Old 13-06-2005, 08:41 PM   #5
5speedeb
now with 3.73 lsd
worn locks?
cheers...
looks like they used a screw driver and yeah i think the locks are worn
do i have to do the ignition as well coz just for now i wanna do the locks first not really interested in the ignition
Old 13-06-2005, 08:52 PM   #6
santoitaliano
BF F6, APV SR3900
you have two options.
1. Tibbe conversion on door locks, meaning you will have two keys,
or
2. Go to a locksmith and get new door locks keyed up to your existing keys
both options will keep u secure
Santo
Daily:
Bluepower enhanced.
Old 13-06-2005, 11:21 PM   #7
5speedeb
now with 3.73 lsd
any idea on cost for both
i like the first one
Old 14-06-2005, 11:15 AM   #8
santoitaliano
BF F6, APV SR3900
1. see what john wants for them... i dont think he will separate though..
2. call 0414411999 (Rob) (can quote you on both)
but surely try keep deals amongst forums members first..
maybe it might be best to get the complete mod kit and over time change it over...
if you are going to do the doors, you may as well do the boot as well..
ive got all the bits sitting at home.. just need to get around to it..
Santo
Daily:
Bluepower enhanced.
Old 14-06-2005, 10:31 PM   #9
John_LS1
your gonna have to do option 2, the tibbe set i had is now gone.
Old 14-06-2005, 10:53 PM   #10
Kaddis
Kaddis Customs
Kaddis's Avatar
sorry if this is off-topic but does anyone know where i can get a second hand smart lock remote for EF falcon sedan
FG XR6 E-Gas Ute in Ego
Kaddis is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2005, 11:09 PM   #11
INJECTED_250
Custom user title
INJECTED_250's Avatar
the wreckers
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2005, 04:37 PM   #12
MintEAFalcon
1990 EA Falcon S Driver
I just converted my EA to tibbe locks.
The only parts you will need for a tibbe conversion are:
Tibbe barrel - Can be sourced from wreckers. Make sure you have a key so you can remove the old lock. $20 approx
Tibbe lock kit - I sourced mine from Ford. Came with ignition lock, both door locks and the boot lock all keyed alike : which I was very happy with. $140.00
2 new shear bolts - Also sourced from Ford $2
You can get the old barrel off by cutting a groove into the Shear bolt with a hacksaw blade and then removing with a flat-head screwdriver. Very easy but a little time consuming. Loosen the 2 small recessed flat-head screws at the back of the barrel and remove the wire hub that slides into the back of the barrel. Install new barrel!
Door locks are a sinch but you will need to remove the door handles. Boot requires the removal of the garnish, number plate and inside boot cover but again fairly painless.
A worthwile upgrade if you ask me!
Cheers,
Mark.
MintEAFalcon is offline   Reply With Quote Multi-Quote with this Post
