Old 27-06-2005, 04:33 PM   #1
fullysik.com
Dale
Default distributor module for eb
hi all,
went to start my eb fairmiont today and it was kicking over but wouldnt get running. so i called the racv and the bloke rekons its the distributor module thats shagged.... any one got an idea how much it would cost to fix and where to get them from?
cheers, dale
fullysik.com is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2005, 04:46 PM   #2
InitialD
Low and Loud
InitialD's Avatar
You mean a TFI modual. They can be purchased from most auto stores. I normally get a few from pickapart or wreckers as they are cheap as ($5 i think)
its held on my 2x screws on the side of the dizzy
Old 27-06-2005, 04:56 PM   #3
fullysik.com
Dale
oh so there not a massive thing, i thought theyd be like a starter motor size. would it be a big job to do myself?
Old 27-06-2005, 05:02 PM   #4
InitialD
Low and Loud
InitialD's Avatar
they are not a big thing as such, size wise :P
if you have a Gregorys manual, it will tell you how exactly to do this. Not hard once you have done it once. Depends on how good you are with cars ;)
Old 27-06-2005, 05:31 PM   #5
sphell
sphell's Avatar
yeah they always pack up if you get moisture in them. try squirting some WD40 on the connections first. Otherwise, Nick-a-Part will have them, just make sure you get one from a 'half decent' wreck. They are a grey box located on the side of the distributor.
Old 29-06-2005, 12:18 PM   #6
ausmetalforever
would the modual be causing loss of power or even cause your engine to run rich?
ausmetalforever is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2005, 11:22 PM   #7
InitialD
Low and Loud
InitialD's Avatar
No not really, Rich could be MAP, Temp sensor, o2 sensor,etc
