Low and Loud
Ive got a SPECO volt gauge that Im installing in the EA (damn Digital cluster)
I want to connect the Volt gauge up to the alternator to get a accurate reading. Now how can I wire it up so the gauge shuts off when the car is turned off aswell?
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
Piece of ****. Put a relay in the line from the alternator, wire the trigger to an ignition source.
Low and Loud
Thought so rob, thanks ;)
ooga-lagga-ligga-lagga
it would get a more accurate reading straight of the battery, as whats coming straight out of the alternator isnt necessarily whats going into the battery. there will be some volt drop if standard setup.
If you want an accurate reading of the charging rate, wired up to batt would be best |
Oops, I slipped....
needturbo6 said exactly what I was going to say.....
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
The one and only
Depends on what you want to know.
As the car runs of the alternator when running, then InitialD is right. If you want to know what the charge voltage to the battery is then wire it to the battery
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#7 | |||
Low and Loud
All installed, thanks people ![]()
Custom user title
right on
u could use a switch and a couple of relays, to toggle between alternator and battery
