Old 30-06-2005, 06:30 PM   #1
ausmetalforever
Default timing problem
Hey, i got a new dizzy put it my I6 and after puttin it in the car is running like sh*t, it has no power at all and coughs abit when you put your foot down and isnt the greatest to start. I sent it back to the auto elec i got it done from and he couldnt get it running good again. He has told me that the timing isnt set right and that he cant set it properly coz he rekons the harmonic balancer has moved out and what hes lining the timing up with is givin a wrong reading but it was runing alot better before the new dizzy was put it, i changed the dizzy coz the modual was screwing up and it was cheaper to buy the whole dizzy than just buy a new modual. I dont know a whole lot about this stuff so can anyone help me? i have tryed searchin the forums on here but nothin came up that sounds like what is hapening to me.
Thanks
ausmetalforever is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2005, 07:08 PM   #2
Psycho Chicken
Psycho Chicken's Avatar
Yup, sounds like the balancer has slipped, it'll be a ***** to line up.
Your best bet is to find TDC, then mark the balancer and redo the timing to that mark.
Old 30-06-2005, 07:24 PM   #3
ausmetalforever
Sorry mate, TDC? is it a hard thing to do to line it up again?
Old 30-06-2005, 10:13 PM   #4
needfordspeed
TDC = Top dead center.
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2005, 11:30 PM   #5
needturbo6
ooga-lagga-ligga-lagga
needturbo6's Avatar
or just keep advancing the timing slightly till it pings then back it off
i could tell you the way to advance the timing but unless your good with working on cars then it can be a tricky procedure, it would prob be best to get your mechanic to do it.
needturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2005, 05:59 PM   #6
sphell
sphell's Avatar
I didn't think balancers could slip. Wouldn't they have a key on them like the cam gear to stop that from happening?
Old 01-07-2005, 06:05 PM   #7
ausmetalforever
Im not sure but i took to a good mechanic and the harmonic balancer hasnt moved at all, the guy didnt have the timing right and it took the other mechanic 5 mins to fix. Thanks for all the help
Old 01-07-2005, 06:09 PM   #8
sphell
sphell's Avatar
Thought as much. timing is pretty hard to set on these engines if your replacing the dizzy, it's easy to get it a tooth out. A lot of the time you'll find that you set the base timing perfectly according to the Ford manual and it's nowhere near being right. You have to advance it a heap before the thing will actually fire up.
Old 01-07-2005, 06:38 PM   #9
Psycho Chicken
The balancer doesn't slip on the crank, the outer ring on the balancer slips from the inner.
Old 01-07-2005, 07:13 PM   #10
Walkinshaw
Two > One
Walkinshaw's Avatar
The balancer is made of 2 or 3 rings bound to each other and they can slip on eachother.
