30-06-2005, 07:44 PM | #1 | ||
fitted mpfi setup today still using the old dizzy it runs fine but does not advance that much only 10 deg at most giving 20 deg total what would be causing this .
Is this normal for converted cars cause its really doesnt want to rev above 2 grand also the iso is not working would this have a issue this problem |
30-06-2005, 08:37 PM | #2 | ||
would it be in the limp home mode cause all this problems
01-07-2005, 08:41 AM | #3 | ||
thanks for the help
01-07-2005, 08:55 AM | #4 | ||
PM me if you want
My car was way retarded when it would not rev about 2grand
run the timing to about 10deg advanved see if it pings and revs out more, if not you will be on the right track.
01-07-2005, 08:57 AM | #5 | ||
the base timing is set right even tryed more timing i think its in limp home mode but cant work out why
01-07-2005, 09:03 AM | #6 | ||
PM me if you want
limp mode should be 3rd gear only, it will still rev all the way out, will just be very slugish off the line and driving along, can you rev it above 2 in neutral
01-07-2005, 09:06 AM | #7 | ||
yeah it does change gear and everything kicks down and stuff just will not advance the timing as much as it should
01-07-2005, 09:07 AM | #8 | ||
plus i dont know why the isc is not working done everything www.ford-tech.com guide said to do
01-07-2005, 09:12 AM | #9 | ||
PM me if you want
to test ISC is very simple, turn idle down till the car is at about 500rpm, then disconnect the ISC, if it stalls it is working, if it doesnt notice then it is doing nothing
01-07-2005, 09:13 AM | #10 | ||
PM me if you want
Have you checked the TPS is at 1v at closed throttle and max of 4.5v at WOT.
01-07-2005, 09:16 AM | #11 | ||
not yet which one of the two should i be checking
01-07-2005, 09:23 AM | #12 | ||
PM me if you want
with ign on (car not started) the green wire is the positive lead, and then earth the multimeter to the body, then with a reading, turn the throttle to WOT by hand and see what it says.
01-07-2005, 09:25 AM | #13 | ||
thanks dellboy i will go check the now
01-07-2005, 09:36 AM | #14 | ||
ok both tps senser are show .780 closed and 4.38 wot
01-07-2005, 09:42 AM | #15 | ||
PM me if you want
OK TPS is supposed to be 1 at closed, so loosen the screws and try adjust it to be in spec, if not adjustment left, then elongate the holes to give you the adjustment.
Tip: Easy way to allow adjustment for testing to decide if its the problem is remove one screw and leav eit out then you can get it within spec tighten remaining screw and test
01-07-2005, 10:22 AM | #16 | ||
kool that has help alittle but still the timing is not advancing like it should only get to 20deg max when with the cfi was get up around 35 starting to think its the dizzy
01-07-2005, 10:36 AM | #17 | ||
PM me if you want
Are you still using the CFI dizzy as they have no PIP signal for TDC this could be your problem.
01-07-2005, 09:20 PM | #18 | ||
yeah i am still using it im getting a hole mpfi wiring loom asap with a mpfi dizzy if this dont work im going back to cfi since it went harder
01-07-2005, 11:07 PM | #19 | ||
Hmmm Gold!!!
when i did mine, i found an MPFI loom and left my CFI dizzy exactly where it was, runs smooth as and gets lot of power out of it
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
02-07-2005, 12:00 AM | #20 | |||
Low and Loud
Just change the dizzy like we said to you at pickapart and set the timing correctly to the IGN mark
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
02-07-2005, 05:15 PM | #21 | ||
it was not the dizzy at all it was the fact with the cfi ecu wiring loom some of the wires did not match up to the mpfi loom with some help from my dad i rewire the isc back to the ecu and the car goes great just to let people now there are a few differnces between
some of the wiring looms that are easy to fix thats not shown in the www.ford-tech.com doco |
02-07-2005, 05:53 PM | #22 | ||
well that would do it every time
NO ONE DIES A VIRGIN AS THE WORLD SCREWS US ALL :thebirds: |
02-07-2005, 11:30 PM | #23 | |||
Low and Loud
03-07-2005, 10:30 AM | #24 | ||
there is more then that one wire wrong mick
