Old 06-08-2005, 06:43 PM   #1
QUIKXR6
Kurucu Performance
QUIKXR6's Avatar
Default EL XR6 ABS & AIRBAGS warning lights...how to reset it?
Hi guys...just wondeirng if anyone here knows how to reset the abs box so the warning light on an el xr6 manual switches off and how to reset the air bag warninglight aswell on the el xr6...we recently changed the rotors on the car...the rotors are abs ones.... the airbag had to be removed to pull off the dash so therefore the airbag warning light has also come up....anyone who can help fix this up...please post.... THANKS
174rwkW N/A I6 Kurucu Performance Enhanced...
Heathcote Test & Tune 28/08/05 - 14.0902 @ 97.61mph
Now With EL XR6 Engine & ECU & 3.7 Gears
Www.KurucuPerformance.Vze.Com
QUIKXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2005, 03:31 PM   #2
EL_futuraistic
EL_futuraistic's Avatar
Default as far as im aware
as far as im aware, the only person who can reset this is Ford. Or there are mobile businesses such as Code Clear who come out and clear it for you for around $100, which im pretty sure is more expensive than ford, but i could be wrong.
hope that helps
EL_futuraistic is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2005, 04:26 PM   #3
ratter
ratter's Avatar
Any decent workshop should be equipped with a scan tool and should be able to clear it for you for a lot less than $100, but if it comes back and you want them to diagnose the problem, it could easily go over $100
Old 07-08-2005, 04:38 PM   #4
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
There must be a problem with the ABS still, the light shouldn't come up just because you have changed your rotors, and the ABS light usually clears itself once the fault is fixed.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2005, 04:41 PM   #5
b2tf
not here much anymore
b2tf's Avatar
Airbag had to be removed to take off the dash? I'm assuming you mean passenger one, if so can I ask why the dash was removed? Last time i checked you dont need to take it out to put new rotors on.
2024 F150 XLT
Old 07-08-2005, 04:45 PM   #6
ratter
ratter's Avatar
if you turned the key on while the airbag was disconnected, that could cause a code to be stored in the computer, but even a low battery voltage can come up as a trouble code which shows from the airbag light, still need a scan tool to clear them even if the problem has been rectified
Old 07-08-2005, 04:48 PM   #7
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Also, have a look at these 2 documents, they should help find out if there are faults with them.
http://www.fordmods.com/forums/documents.php?doc=2
http://www.fordmods.com/forums/documents.php?doc=3
Old 07-08-2005, 09:38 PM   #8
fairmont1998
fairmont1998's Avatar
I'll second what Aaron said, there must still be a fault with the ABS. Once faults are rectified the Check ABS light resets itself.
The Airbag light will need to be reset by Ford or someone with a scanner.
Darin.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2005, 09:39 PM   #9
EFFalcon
Last warning
EFFalcon's Avatar
you can reset the airbag light yourself.
all uyou need to do is ground one of the pins on the diagnostic plug!
EL GT - Supercharged
OFFROADER - Ford Explorer
