Old 16-08-2005, 05:01 PM   #1
bakes_eb
bakes_eb's Avatar
Default Clutch issue
hey guys, i am just wandering i am in the process of doing a t5 conversion and i am unable to get a 4.0L flywheel if i put the 3.9L flywheel onto my 4.0L will i need to modify anything or will everything bolt straight up. o know they arent as strong but i cant seem to fing a 4.0L one anywhere.
thanx scott
bakes_eb is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2005, 05:17 PM   #2
stockstandard
It will bolt right up (Im sure I have said that once or twice before now). The only thing different is that you must use a EA clutch.
Originally Posted by casper
Old 16-08-2005, 05:19 PM   #3
niko
likes falcon's
niko's Avatar
if its all from the one car, u wont have any issues if u bolt it all back up
www.carhubsales.com.au
Old 16-08-2005, 05:53 PM   #4
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
the 3.9 flywheel is 3 bolt the 4.0 is 6 bolt
make sure u get the clutch and pressure plate to match.
BoZZa17 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2005, 06:00 PM   #5
stockstandard
or just get a couple of holes tapped and 3 dowels knocked in and you have turned your 3.9 flywheel into a 4.0 flywheel...
Old 16-08-2005, 06:49 PM   #6
CruizinEB
just get a 4.0 flywheel?
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2005, 08:15 PM   #7
INJECTED_250
Custom user title
INJECTED_250's Avatar
i had an old cross flow fly wheel machined to run an EB 6 bolt clutch. All they done was machine a small step in the flywheel, to center the clutch, and tapped 6 holes in it, cost me less than 50 bucks from memory
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
