Old 30-08-2005, 04:59 PM   #1
RUQ1KA
Formerly mad_ed_wagon
Question EA laggy after gasket change & other problems!
i done a headgasket change to my ghia last week, finally managed to get it driving and out of the garage today, but it seems to still have a few problems,
1st, the injectors have to be in exactly the right position to get it idling right
2nd, once you accelerate it makes a "putt putt putt" sound then starts to rev up
3rd, 0nce on the road, it really lags and idles rough, and once i accelerate still makes the "putt putt putt" sound before it starts moving
4th, the exhaust, when the cars in park & idling, has a stop in it's blow, it sort of blows then stops then blows then stops etc... making a "putt putt putt" sound again (i checked this on the ED and the ED's exhaust blows constantly)
and, when the head gasket was blown the car was blowing water out the exhaust and still does if i rev it a bit or it's on my drive way (on an angle)
so i've sort of run out of ideas on whats up with it..., any one got any ideas on what could be wrong and how to fix it?
2004 BA FALCON XT/GHIA WAGON
Build thread coming soon!
Originally Posted by RogerCordia
I had two cordias but recently i sold one of them so that leaves me with one cordia which i have now but i wouldve had two if i havent sold the other one.
RUQ1KA is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2005, 05:02 PM   #2
RUQ1KA
and by lags... i mean it feels like it has a 2cyl engine in it!!!
Old 30-08-2005, 05:13 PM   #3
old_mate
Smash the Boost
old_mate's Avatar
Timing is out. When I did the head gasket on my EA i setup the timing per timing marks as normal. Turns out my balancer had slipped. I had to then find TDC myself with a coathanger down number 1 plug, mark that with a paint pen, and go from there. Was all good after that...a 1.6L auto laser flogged me off the lights prior to doing all this, so I know how slow it must feel
it also sounds like its misfiring. How are the leads, plugs and dizzy cap/rotor?
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2005, 05:24 PM   #4
neb
hibernating
neb's Avatar
Yeah sounds like timing is out.. or it could even be missing as well? Umm no idea about turning injectors for it to idle right though that sounds weird
neb is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2005, 05:25 PM   #5
old_mate
Smash the Boost
old_mate's Avatar
I just pulled all the inlet out of the way when i did mine lol.
1971 Fairmont Sedan
1974 SWB F100
Old 30-08-2005, 06:26 PM   #6
RUQ1KA
i bought a dizzy cap, and a set of leads when my wagon was playing up a and turned out i didnt need them so i just have them sitting around on the garage floor so might aswell chuck them in the ea, with sparky's anyone know what would be best for an ea on gas? or doesn't it matter?
nick told me to try it and it worked, apparently it was a common problem on this car once he had it, i thought i had it fixed aswell, untill i took it n the road:(
myght just aswell visit JR's and get some injectors, might be the seals or something that are gone (at least thats what my dad says)
Old 30-08-2005, 06:30 PM   #7
Psycho Chicken
Psycho Chicken's Avatar
If you have to rotate your injectors to get it idling right they are rooted. They should be firing a cone spray, obviously they aren't.
Old 30-08-2005, 06:48 PM   #8
TuMor
its not a!
TuMor's Avatar
Youve got me worried now, my car spits a bit of water if i rev it.
From what ive heard thats a good thing, show its burning nicely.
TuMor is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2005, 06:50 PM   #9
Psycho Chicken
Water is a by product of catalytic convertor operation.
Old 30-08-2005, 07:18 PM   #10
RUQ1KA
so how come my ed or my old ea dont do it?
Old 30-08-2005, 07:22 PM   #11
Psycho Chicken
How much water depends on what gases the engine is putting out. No two will be the same.
Old 30-08-2005, 07:37 PM   #12
niko
likes falcon's
niko's Avatar
playing with injectors was only a suggestion as i figured not everything was perfect and clean wen it was bolted back together... i had a mate come around once, "nik man my cars idling like a prik"
i had a look and an injector plug come out lol
www.carhubsales.com.au
Old 30-08-2005, 08:33 PM   #13
Walkinshaw
Two > One
Walkinshaw's Avatar
water is a byproduct of combustion. Depending on the batch of fuel will impact on the H2O quantity. LPG cars drip water something chronic.
Old 30-08-2005, 08:50 PM   #14
Brent-EA Ghia
Brent-EA Ghia's Avatar
Did you make sure the timing chain didnt skip a tooth on the cam gear, usually use two zip ties around the chain while on the gear. Were all the leads numbered, if not double check that there in the right order. The dizzy shouldn't be out, its not usually moved when doing the head, so unless you did move it i wouldnt change its position, but changing the cap and leads is fine. Thats a few things
Also if the oil is still creamy (has water in it) it can cause the lifters not pump up correctly, causing it to miss.
Proud Owner of 06' TTG
Brent-EA Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2005, 10:04 PM   #15
RUQ1KA
i marked the cam gear so im sure it didnt skip
& leads were numbered
Old 30-08-2005, 10:18 PM   #16
INJECTED_250
Custom user title
INJECTED_250's Avatar
is it on gas as well?
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2005, 10:24 PM   #17
InitialD
Low and Loud
InitialD's Avatar
tommi, if you can get your hands on a Timing light and check its all good.
If you need a set of injectors, ive got a spare set of working EA ones
Old 30-08-2005, 10:24 PM   #18
RUQ1KA
it's on gas but doesnt run on gas yet, gotta fix that still
