12-11-2005, 01:02 PM | #1 | |||
Back to Le Frenchy
My cruise control just up and died the other day on the way home from work. The buttons weren't too healthy and after pushing them hard for a while they completely broke so I replaced them. But to my shock still no cruise control. Any one else had this problem or know what would be causing it?
12-11-2005, 01:10 PM | #2 | ||
Mine wouldn't turn off at all and when you did, the cruise would lock onto a speed. Ended up being the cruise computer was buggered. Cost for my eb 120 just for that. Hope i helped you greenel.
Bill Last edited by EBII Fairmont; 12-11-2005 at 01:15 PM. |
12-11-2005, 01:43 PM | #3 | ||
I had this problem with the EF Ghia, it turned out to be a faulty brake switch. (worked it out and replaced it same day)
Heritage Green EL Ghia Black AUII XR8 Ute |
12-11-2005, 01:48 PM | #4 | ||
Does your horn still work?
AUIII Falcon Forte, with SIX Appeal |
12-11-2005, 02:57 PM | #5 | ||
Sykmat
I just had the cable replaced on mine the buttons were working fine but nothing was happening now works fine. cost me $150 with labour included. that was in a EL a new computer is about $600 i think.
12-11-2005, 03:34 PM | #6 | ||
When I first got my car the cruise wasn't working, after stuffing around putting in some cable from the battery into the cabin and unplugging the cruise module to get it out of the way then plugging it back in again it worked! So maybe try that first.
Mine is now dead again and unplugging the module doesn't solve the problem, along with checking the brake light switch (assuming both the brake lights and the cruise work off the one switch the brake switch will be ok if you have brake lights working, can't tell if they're seperate swtiches on my wiring diagrams and there's only one on the pedal) also check the clutch pedal switch, if it's connected, dunno if you would've hooked it up with your conversion Also check the brake pressure switch which I'm assuming is the switch on the master cylinder? Can anyone else verify that or have the correct location? The diagram doesn't give a location and the wire colour's match up to the wire's going into the module. Mine's leaking and I've cleaned the terminals up and tried with it plugged in and unplugged and it hasn't fixed it for me.
Ed |
13-11-2005, 11:16 PM | #7 | ||
Mine would only work sometimes,but i chased the problem to the switch at the clutch pedal-now held in place with a zip-tie.
14-11-2005, 12:00 AM | #8 | ||
Parts bin special
My cruise control is slowly dieing as well. My "Set Acc" button works about 50% of the time. My "Cst Res" button only about 5% of the time, so I basically have to rely on the "Set Acc" button. I asked the mechanic about it and he checked the metal rings on the back of the steering wheel for wear and tear. They still looked pretty good though. Have you checked them? If there's no contact between the metals, the cruise won't work
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
14-11-2005, 12:04 AM | #9 | ||
Ckeck the switch at the brake pedal, often its not in properly and wont allow the cruise to engage. Remember the button on the switch has to be fully depressed against the pedal.
14-11-2005, 01:07 PM | #10 | |||
Back to Le Frenchy
If it is the switch causing the problem would the brake lights still work?
14-11-2005, 01:14 PM | #11 | ||
can anyone give me a diagram or info on the wiring for cruise.....the bits for the aftermark wheel.....which wires go onto which metal contact etc etc
