Old 29-11-2005, 03:10 PM   #1
vegabass
BASS ON BOARD!
vegabass's Avatar
Default EF XR8 Question
Can you change the MAF from the standard one to a EL GT one with no dramas?
or will that upset some fancy ford thing that will make the car explode if we change it?
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 04:39 PM   #2
NZ
NZ's Avatar
Fraid not.
To use the maf you'll need the EEC anand 24# injectors.
you can use the housing with your standard electronics but this will cause some drivability problems.
Old 29-11-2005, 04:53 PM   #3
EF302
Originally Posted by NZ
Fraid not.
so how are people using au maf with out changeing the eec? i was under the impression that it was the injectoers only?
thinking of doing this my self,so need advice also.
thanks
EF302 is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 05:30 PM   #4
mcflux
mcflux's Avatar
E-Series sensor stays. Just the MAF housing gets changed (for larger AU size).
This may cause some tuning problems (idle or flat spots) but I never experienced any of these. I have an ex-NZ maf in my EB :P
-Dave-
Old 29-11-2005, 06:47 PM   #5
*rayman*
454 Power
*rayman*'s Avatar
I never experienced any problems while i had 75mm on my ef xr8.... is for sale at $300 with the el gt air box venturi, including post if you're interested.
DAILY - 00 75th Anniversary Futura
TOY - 68 SS 454 Camaro
*rayman* is offline   Reply With Quote Multi-Quote with this Post
