03-12-2005, 10:21 PM | #1 | ||
hey guys, i have a query for some of u in the know,
i have a 93 ed fairmont that i have just converted to manual, the diff ratio is currently 3.08. i have previously owened a eb falcon 5 speed with 3.27 ratio and seemed to accelerate so much quicker, so my question is what gear ratio should i choose for my car now and were can i buyu gear ratios from: does anyone know were to find 3.7 lsd's centers and how much they would cost? any info would be great guys cheers |
03-12-2005, 10:25 PM | #2 | ||
if i were in your position i'd try and tranck down a 3.45:1 LSD from and EB-ED XR.
03-12-2005, 10:26 PM | #3 | |||
Back to Le Frenchy
Personally I would (and I am soon) just go to the wreckers and get a disc to disc diff from a XR with the 3:45 gears. That should help your acceleration probs.
04-12-2005, 12:05 AM | #4 | ||
cheers guys i'll take this advice, any idea what an xr 3.45 lsd might set me bak?
04-12-2005, 12:13 AM | #5 | |||
Back to Le Frenchy
last time I checked they were around the 550 to 650 mark for the EL.
04-12-2005, 12:14 AM | #6 | ||
likes falcon's
you also have to take into consideration, in what condition the diff is in and the rest of your driveline...
and some t5's are slightly different geared.
www.carhubsales.com.au |
04-12-2005, 07:28 PM | #7 | ||
i would g0 3.7's... good highway gear, and even better than 3.45's. Rollin had 3.9's and he was able to do 1.9 second 60ft's at the drags. the good thing about getting a complete xr diff is that you have the lsd, but then you dont know the condition, so it may need a rebuild which will cost around $500, which is the same as a rebuilt replacement lsd.
if you have any questions please ask me or Rollin...
Powered by Rollin Motorsport Turbo Barra ED 4L
04-12-2005, 08:55 PM | #8 | ||
GMHKLA number plates
pfft go 4.11s mate lol im after 3.7s for my car but i can easly get it thru work so im covered.
Currently owned: 1997 Hyundai Excel (the daily) 2009 FG FPV F6 Silhouette Auto Previously owned: 1994 EF fairmont Ghia 4.0Ltr, AUTO 14.620@93.3mph 2000 Honda S2000 14.73@92mph (stock + no traction) |
06-12-2005, 02:30 PM | #9 | |||
06-12-2005, 02:50 PM | #10 | ||
my mate just put a lsd centre in his 3.27
now he has 2 phatties and can't believe how good it is if any one has a lsd centre they wish to offload PM me |
07-12-2005, 10:21 AM | #11 | ||
i normally have a 3 speed manual.. 1, 3, 5... or 2, 4, 5... easy to skip gears if you want...
the only reason i am happy with 4.11's is that i have a taller 5th gear. otherwise i wouldnt go that shorter diff gear. 3.9's would be the highest i would go... definitely worth it though...
07-12-2005, 11:35 AM | #12 | ||
I'd go 3.9's max. Depends on what box you have in it but a lot of the time if you go higher like 4.11's then you'll be doing an extra gear change just before the line at the drags. 3.9's will have u almost at the redline b4 u cross the line.
07-12-2005, 11:43 AM | #13 | ||
when i had 3.9's i was doing like 4700rpm at the line, same with Rollin... now with 4.11's its a bit closer to 4900...
but now with a nice big cam (2400rpm to 5800rpm), limiter moved to 6000rpm, i'll got a bit more out of the bad girl...
07-12-2005, 01:07 PM | #14 | ||
I have 3.45:1 LSD and can do 2.060 60 ft times on 17s straight off the street. EL XR8 manual. Yet i can still get under 10L per 100km on a trip sitting on 115-120kmh. I am very happy with this gearing for an all round ratio.
07-12-2005, 01:14 PM | #15 | ||
your poor clutch... very impressive though...
what clutch are do you have... what rpm do you launch at?
07-12-2005, 03:16 PM | #16 | ||
I have know idea what clutch but it is quite firm. after 9 consecitive runs with 2nd gear burnouts I could just start to feel it go off a little. I cant remember exactly what rpm, didnt get it totaly sorted but around 2800-3200 rpm, take up the slack, Let clutch out and just drive on the right foot untill its up and going. done 2 runs out of 9 into the 2.0's 60ft. and 3 in the 2.1's
With a better reaction time and good tyres would cut a lot off the ET and 60ft's |
