Old 05-12-2005, 11:23 AM   #1
XRated
Shoot.
XRated's Avatar
Default This look right?
I need a quick definite answer before I bolt up the bellhousing and everything, can someone tell me if the clutch fork is facing the right way:
Also, how do I route the clutch cable? Do I have to put a little bracket/guide somewhere?
Thanks
20V Turbo
Old 05-12-2005, 12:17 PM   #2
oneredED
need more boost
oneredED's Avatar
To me that looks the wrong way around :S
We routed the cable accross the bottom beside the PS rack, and then up to and through the firewall... (it goes through that hole on the bellhousing to the left of the fork in that pic).
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2005, 12:19 PM   #3
XRated
Shoot.
XRated's Avatar
So the stove & clutch fork should face the front of the car?
20V Turbo
Old 05-12-2005, 12:25 PM   #4
Papa Smurf
Papa Smurf's Avatar
Did you change the bush? If not then the Fork is in wrong. :(
Clutch cable can only go one way. Different fittings on End.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2005, 12:25 PM   #5
TUFED6
TUFED6's Avatar
Wrong way around, the end of the clutch cable goes through the hook on the end. The cable on mine runs along the bottom of the steering rack.
- John
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2005, 12:26 PM   #6
oneredED
need more boost
oneredED's Avatar
I have bad eyesight, but to me the doodad that comes out of the side of the bellhousing should be facing the other way, the prongs on that little frankfurt sized piece should face the front of the car, and the cable hooks in there and then goes through the hole at the front of the bellhousing.
Please correct me if i'm wrong people, i don't 100% remember and CBF looking for sure (sorry luke :P)
'94 ED Falcon GLi
Power from: ???
Cost: stuff all :P
Old 05-12-2005, 12:34 PM   #7
INJECTED_250
Custom user title
INJECTED_250's Avatar
that is defently looking like the wrong way round
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2005, 06:08 PM   #8
XRated
Shoot.
XRated's Avatar
LMAO I knew it!!!! Lucky I didn't bolt the mofo up. So over this car.
20V Turbo
Old 05-12-2005, 06:54 PM   #9
EFFalcon
Last warning
EFFalcon's Avatar
its not the cars fault :P
its YOUR fault :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 05-12-2005, 07:01 PM   #10
snypereb
[EBGLT]
snypereb's Avatar
totally wrong way around get back under there!!!!!!!
[EBGLT]
Old 05-12-2005, 07:10 PM   #11
Psycho Chicken
Psycho Chicken's Avatar
It's also my fault haha. Luke you should know better than to listen to me! After all I'm living on 5 hours sleep most days!
Old 05-12-2005, 07:37 PM   #12
Damo
looks like ya allmost there luke. Sorry i couldn't give you a hand on saturday, i got caught up with other stuff.
Route the clutch cable over the top of the steering rack. I dunno how you got the fork in there like that ? have you got the throw out bearing attached to it ? Make sure you lightly grease the input shaft too so the bearing slides nice and smooth and doesn't dry out and become noisy.
Old 05-12-2005, 08:15 PM   #13
XRated
Shoot.
XRated's Avatar
Didn't want to point the finger ROFL!!!
Ahhh f@rk this whole thing. Now, the fork goes on the other way around, then the bearing, but what way does the bearing face? :
For sale: 1/2 complete project.
20V Turbo
Old 05-12-2005, 08:25 PM   #14
Damo
the bearing faces goes infront of the fork, this is what engages and dissengages the clutch. The bearing will click into the fork.
Have a look at this link, I remember when i did my conversion on the EA even after putting it all in I still didn't understand how it all worked. This explains it and has a couple of cool interactive diagrams. :P http://auto.howstuffworks.com/clutch1.htm
Old 05-12-2005, 08:26 PM   #15
Psycho Chicken
Honest, the workshop manual is hard to read. Come over and look at it yourself :P
Real clutches need hydraulics anyway.
Old 07-12-2005, 01:40 PM   #16
XRated
Shoot.
XRated's Avatar
Ahhhh okay, second attempt:
Just need to know if the bearing is on the correct way?
20V Turbo
Old 07-12-2005, 01:43 PM   #17
oneredED
need more boost
oneredED's Avatar
Yep (correct me someone, i'd hate stuff Luke up). It should click into the clutch fork though... You'll know if it's the right way around, because the bearing will "click" into the fork when you press them together. You should be able to see little prongs and gaps where they line up (2 tiny prongs, 180* apart)
Is that bearing new? May as well replace it now Luke while you can ;)
'94 ED Falcon GLi
Power from: ???
Cost: stuff all :P
Old 07-12-2005, 01:45 PM   #18
XRated
Shoot.
XRated's Avatar
Yeah LOL it is new, just dirty from grease and stuff. I don't see how it should "click" in though? What's your MSN mate?
20V Turbo
Old 07-12-2005, 02:05 PM   #19
XRated
Shoot.
XRated's Avatar
Okay, now to get this bearing secured properly...
Here is my dodgy diagram! (Bearing top, fork bottom)
Is that all I need to do? It doesn't seem very secure/tight. :
(Jared, my MSN won't reconnect grrrrr)
20V Turbo
Old 07-12-2005, 02:26 PM   #20
neb
hibernating
neb's Avatar
yeah it just kind of hooks on by those 2 bits, it will be kinda loose and be able to move thats fine.
edit: you should have the bearing attached properly to the clutch fork before you put the gearbox in
oh and good choice of clutch
neb is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 04:22 PM   #21
Damo
clean that grease off the input spline, but leave the bit the bearing slides on geased up. You don't wanna get all that crud in ya new clutch.
