Old 09-02-2005, 04:14 PM   #1
EA2BA
PM me if you want
EA2BA's Avatar
Exclamation Wanted Urgently AU 4 speed auto wiring diagram
Any one got the AU 4 speed auto wiring diagram, need to confirm wires and pins thanks.
PM me and I will give you my email address if you need it.
Old 09-02-2005, 05:34 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
would it be hugely different to ef/el?
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 09-02-2005, 05:35 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
Yeah something about using hi-side wiring vs low-side wiring of ea-el, smoething like that, its what I have heard, need to check it all out.
Old 09-02-2005, 05:54 PM   #4
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Of course you could also look HERE where there is a perfectly good copy.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2005, 05:56 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
ummm errr, yeah i spose i could do that.
thanks
Old 09-02-2005, 06:06 PM   #6
EA2BA
PM me if you want
EA2BA's Avatar
I searched this time, but cant find the EEC-V pin assignments
Old 09-02-2005, 08:40 PM   #7
russellw
russellw's Avatar
A look at this HERE might help as might the other 3 articles on the EEC-V.
Russ
Old 30-09-2012, 04:38 PM   #8
chargedfalcon
Default Re: Wanted Urgently AU 4 speed auto wiring diagram
Just done a 5 speed conversion on my AU and have used the auto ECU to save having the ecu and BCM matched and also swapped engines so had the manual loom so didnt need to do any re-wireing, all works fine though thermo fans run all the time, Iam after the wiring diagram of the auto to locate which wires and plug pins are the right ones for the PTC to put in a new resister to stop the thermo's running. Can any one help?? Thanks in advance. Cheers Keith.
chargedfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2012, 09:26 PM   #9
rmack
rmack's Avatar
To stop the ECC thinking the transmission is overheating (Fans running nonstop) you need between 57ohm - 15.5kohm resistance between pins 37 & 91.
12-14Kohm should work nicley. Yellow wire and Tan Wire/Red trace (big round plug)
Drawing in Wiring Schematics/Au Falcon/Au Falcon Wiring Diagrams Page 24-4-82
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
