10-02-2005, 07:04 PM | #1 | ||
Hello, i was just wondering if there was a difference in lenght from EA-B-D throttle cables. or are they all the same? thanx alot for your help.
10-02-2005, 09:32 PM | #2 | ||
ooga-lagga-ligga-lagga
EB ED Multipoint throttle cables are definitly the same, dunno for sure about EA's but im pretty sure there are the same.
11-02-2005, 09:23 AM | #3 | ||
2 Throttle Cables;
1) EA,EB,ED with multipoint motors are all the same, 2) EA, EB sesriesI with CFI motors have a shorter throttle cable, Cheers Luke.
EL FAIRMONT Pacemaker 4499's Megaflow 2.5in Cat X-Force 2.5in Sports Exhaust Champion STEEL igntion leads K&N panel filter, EL GT Snorkel, modified airbox 16in Speedy Holotype-R mags on 225 tyres |
11-02-2005, 09:29 AM | #4 | ||
PM me if you want
Throttle cables for MPFI are al lthe same, but the bracket on the throttle body is different between EA 3 speed and the other EA-ED's, for that matter the throttle body has slightly different connecting arm to throttle cable as well.
11-02-2005, 06:03 PM | #5 | ||
If all the cables for multi point are the same, then they changed the throttle body conection slightly, how would this matter, so any T/B wil fit on any manifold, with any cable, all being multi points of couse..(EA-D)
11-02-2005, 07:39 PM | #6 | ||
windsor user
early EA's (with the 3 speed auto) had a differnt linkage because the 3 speed is a mechanical box, and has a kickdown cable wich attaches to the throttle body linkage.
later EA's (with the 4 speed auto) onwards had a tps (throtle position sensor) and no kickdown cable (as the box is electronic not mechanical) and thus why they have a different linkage |
