Old 30-12-2005, 05:14 PM   #1
snypereb
[EBGLT]
snypereb's Avatar
Question HELP!!! Whats next?
What could possibly be wrong with my car? I have done everything!
Spark Plugs
Leads
Dizzy
Dizzy Cap
Rotor Button
Injectors
Fuel Filter
Accelerator Cable
When your at the lights it lags unless you take off with really small accel. Then gets up to speed and you give it the boot and it lags again and jolts and spits and coughs!!! What the f!@#?
Shaun
[EBGLT]
Old 30-12-2005, 05:15 PM   #2
TuMor
its not a!
TuMor's Avatar
Flooded it mate.
TuMor is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 05:16 PM   #3
snypereb
[EBGLT]
snypereb's Avatar
Who knows flooded with money that what it is!!!!!
[EBGLT]
Old 30-12-2005, 05:17 PM   #4
Jason[98.EL]
Jason[98.EL]'s Avatar
bad fuel where did you get it from
[SIGPIC][/SIGPIC]
Old 30-12-2005, 05:22 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
Some little private fuel joint in maribynong im having trouble with timing to any hints?
[EBGLT]
Old 30-12-2005, 05:24 PM   #6
ebxr8240
Performance moderator
ebxr8240's Avatar
Chack the TPS voltage? It should be under 1v @ idle and pregressivley go up to 5v @ wot..Check koeo.. Check inlet leaks or hoses off inlet etc...
Daily driver GTE FG..
Old 30-12-2005, 05:26 PM   #7
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
Get a biger radiator
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 05:29 PM   #8
snypereb
[EBGLT]
snypereb's Avatar
Is the mark on one of the front wheel things the timing mark and its supposed to be in the middle of those two thing that poke out of the block!
What a TPS?
Whats the koeo?
[EBGLT]
Old 30-12-2005, 09:52 PM   #9
sphell
sphell's Avatar
possibly a faulty oxy sensor? My EA used to flat spot because of that.
Old 30-12-2005, 09:55 PM   #10
svo347
AFF's 1st DM.......
svo347's Avatar
throttle position sensor
Key On Engine Off
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 30-12-2005, 10:24 PM   #11
Damo
i think i suggested this allready, but it's not a blocked cat or exhaust ?
Old 30-12-2005, 11:53 PM   #12
triple8nitro
Alternator
Exclamation
Have you done a compression check or checked the vacuum hoses ?
triple8nitro is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 12:32 AM   #13
Brent79
I reckon its a vacuum leak also. I also reckon that you'll find the leak right near where the MAP sensor feed tube connects to the manifold. Check it out coz it sounds like a A/F ratio problem to me...
Brent
Brent79 is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 01:52 AM   #14
EDXR6T
yer that hose from the manifold allways get holes right next to the valve that's conected the the manifold wen i swaped a manifold of the one i was puttin on had that problem.
u sould b able to get to it fearly easy just have to feall for the right hose
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2005, 09:19 AM   #15
snypereb
[EBGLT]
snypereb's Avatar
We did that map sensor thing with the hose and there was no leaks. Ill get a compression check done on it when it gets sent away on the 3rd and we have all checked the exhaust and the cat and there is nothing there either its internal/ electrical for sure im just leaving this one to a pro i have done my bit!!!
[EBGLT]
Old 04-01-2006, 02:20 PM   #16
snypereb
[EBGLT]
snypereb's Avatar
Thats it i have had enough boys shes gone to the mechanics today probably wont see her for a week or so hope i can have her back for the cruise!!!!
[EBGLT]
Old 04-01-2006, 04:48 PM   #17
efgiar
rofl copter
efgiar's Avatar
id say timing, or ur tps... one of the 2
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2006, 05:00 PM   #18
snypereb
[EBGLT]
snypereb's Avatar
What do you mean by tps?
[EBGLT]
