Old 31-12-2005, 11:55 PM   #1
gthofan
Gunna girlie-man
gthofan's Avatar
Default brakes lock, why???
hey guys, just a quick question, ive got a manual ea, with a limited slip diff, and to the point... i downshift as i approach a red light, 3rd to 2nd at 70km/ph, 2nd to 1st at bout 40km/ph, and the brakes lock for a bees extension of a second, sometimes they squeak twice, and the tyres and brakes are perfect, bout 90% tread on all tyres, why is this happening??
any help much appreciated
cheers
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 12:27 AM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
Too much rear brake when stopping..Remember weight transfers to the front when stopping ...
Daily driver GTE FG..
Old 01-01-2006, 12:29 AM   #3
gthofan
Gunna girlie-man
gthofan's Avatar
no thats the thing
im not using any brake to slow down. only gears.
when i change down to 1st at about 40km/ph, the brakes lock for a millisecond,
if its in the wet, i may keep slipping
Old 01-01-2006, 12:58 AM   #4
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Its called compression braking. Its actually the engine locking the rear wheels as you let the clutch out on the downshift. might try being smoother (match the revs when you downshift by giving the throttle a blip while you're in neutral) to eliminate this and extend the life of your diff/gearbox/clutch. You should pretty much not shift into first while moving at more than 20km/h or so anyway.
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 01:03 AM   #5
Bad.Karma
What are the cogs like for EAs? is 40 a little fast to change back to 1st?
Bad.Karma is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 01:06 AM   #6
gthofan
Gunna girlie-man
gthofan's Avatar
hey thanks gammaboy, your a very learned fellow,
u learn something everyday, good way to start the year.
thanks and have a good 1
cheers
Old 01-01-2006, 01:06 AM   #7
pandaman
Back in Blue!
What he said. Compression lock up is pretty hard on the drivetrain, if you're gonna be doing that sorta thing, a bit of the old double shuffle might be the go. You'll find that it feels a lot smoother as well once you get the hang of it.
Previous Ride 1: XE wagon 4.1 on LPG - RIP
Previous Ride 2: VN Berlina wagon 5.0 EFI
Current Ride : EF XR6 wagon (Manual!)
Back in Blue baby!
pandaman is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 01:08 AM   #8
Bad.Karma
WTF? go read a book uni boi!
Old 01-01-2006, 01:09 AM   #9
gthofan
Gunna girlie-man
gthofan's Avatar
well i think the dillema is solved!!!!
Old 01-01-2006, 01:16 AM   #10
Gammaboy
Gammaboy's Avatar
cheers
No worries chief. Glad to have been of service.
Old 01-01-2006, 01:29 AM   #11
XR Martin
XR Martin's Avatar
Gears are for going not slowing.
I would only use the gearbox to slow down if I really need to stop in a hurry.
Brakes are cheaper than drivetrain components
2004 BA wagon RTV project.
Old 01-01-2006, 06:12 PM   #12
Obriza
Obriza's Avatar
I agree with gammaboy, id say your just gearing down too early.
Obriza is offline   Reply With Quote Multi-Quote with this Post
