Old 04-01-2006, 01:13 PM   #1
MustangNicko
MustangNicko's Avatar
Default Trip computer on EL
Hey guys
Just wondering what the process would be on fitting up a trip computer to my EL XR6. Is it just a matter of replacing the stock clock unit with the trip unit and plugging it in or does it have to be wired up?
The clock screen in the car is buggered, the light wont come on, so i thought id give the trip unit a go.
Nick
MustangNicko is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2006, 01:29 PM   #2
CruizinEB
if i remember correctly there is about 4-5 other new wires and you NEED the loom plug for it to work ;)
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2006, 01:33 PM   #3
MustangNicko
And how hard would it be to get all these parts or hooking it up? Is it worth it?
Old 04-01-2006, 01:39 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
you need to use the existing wiring from the clock, you also need to run a wire from the cluster to the trip computer and possible tap into 1 other wire.
There is a doco on it on fordmods.com
its pretty easy.
if you get a trip computer, grab the plug for it too.
hxxp://www.fordmods.com/forums/documents.php?doc=32
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 04-01-2006, 01:58 PM   #5
CruizinEB
i had to do heeps more wiring :(
Old 04-01-2006, 03:00 PM   #6
GenesiS
*Smart *** comment here*
GenesiS's Avatar
I just did my EL GLi yesterday... not hard... theres three wires you have to run to the standard clock plug... only one thats pain is from the RHS dash connector, to get to it you hve to take the dash fascia out and the dash... but it allows you to hide/run the wiring really easily when it's out...
All in all its not to hard... just a ИИИИИ pulling the car apart....and making the wires go in to the existing plug... or you could just askefor the plug with the unit and snip the exisiting wires and re-solder!
1997 4.0L EL Falcon GLi Sedan Auto
2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe
Lowered all round on King Spring Super Lows
Tinted Windows, Pioneer MP3 Player and Audio System
K&N High Flow Air Filter Mounted in Original Air Box
Trip Computer
NGK Sports Performance Leads
NGK Sports Plugs
Autotecnica Oil Catch Can
GenesiS is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2006, 07:24 PM   #7
LowEL2XR8
Mr Impulsive
LowEL2XR8's Avatar
I have the Ford instruction sheet for fitting EF/EL trip computers to non trip computer equipped model, GLi, Futura and XRs.
Its rather easy with these instructions/diagrams.
PM me if you want a copy.
Owned Fords
85 Telstar (man), 96 EF GLi (auto), 95 EF XR6 (man), 97 EL Fairmont Ghia (auto), 98 EL XR8 (man), 06 BF wagon (auto), 06 BF XR6 (ZF auto), 08 FG G6E (ZF auto), '10 SY MKII TS Territory (4spd)
LowEL2XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2006, 10:57 PM   #8
MustangNicko
Sweet
Thanks for you help guys, ill give it a crack.
PM send LowEFGLi
