Old 06-01-2006, 05:42 PM   #1
slamd ef wagon
Default lsd diif oil
whats the recomended weight for a falcon lsd?
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS
slamd ef wagon is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 05:55 PM   #2
Damo
Hypoid gear oil 80w 90
Old 06-01-2006, 06:08 PM   #3
Walkinshaw
Two > One
Walkinshaw's Avatar
I was under the impression that Hypoid was for open centre diffs.
LSX80 is what i was under the imprssion was the correct fluid.
Old 06-01-2006, 06:12 PM   #4
slamd ef wagon
ok cheers i was looking at some penrite stuff said it was for h/d and lsd,s was called limslip for memory(i think) but there was 2 weights but damo cleared that one up
Old 07-01-2006, 01:41 PM   #5
slamd ef wagon
bump__
Old 07-01-2006, 01:59 PM   #6
Psycho Chicken
Psycho Chicken's Avatar
80w/90 is for the open wheelers.
LSX90 for the LSD.
Old 07-01-2006, 02:11 PM   #7
EF_Frmnt
EF_Frmnt's Avatar
mhmmm lsx90 is the stuff... fill it up til it comes out the hole
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2006, 03:29 PM   #8
EF_Frmnt
EF_Frmnt's Avatar
and also putt in some anti chatter diff oil additive.. makes it a bit less likely to start making noise.
Old 07-01-2006, 03:41 PM   #9
Psycho Chicken
No ammount of additive will ever shut up a BW diff.
Old 07-01-2006, 05:29 PM   #10
slamd ef wagon
so will this penrite limslip stuff do it comes in 80-90w and 90-140w i think
Old 07-01-2006, 05:39 PM   #11
cArSiK
worked wonders for mine.
I use Penrite 10/10ths SYN GEAR 80/140
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2006, 08:40 AM   #12
Kenaz
Kenaz's Avatar
On the topic of LSD oils. If a LSD is starting to single spin in certain situations is it worth replacing the oil or is the LSD shagged?
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2006, 11:04 AM   #13
LowEL2XR8
Mr Impulsive
LowEL2XR8's Avatar
Thats what I use. I've just done my first diff oil change to Penrite 10/10ths SYN GEAR 80/140 and it seems to of made a big difference. Doesnt feel as sloppy in the diff now.
I dont think I'll use anything else.
I use Penrite all through my car ie diff, gearbox and engine.
Owned Fords
85 Telstar (man), 96 EF GLi (auto), 95 EF XR6 (man), 97 EL Fairmont Ghia (auto), 98 EL XR8 (man), 06 BF wagon (auto), 06 BF XR6 (ZF auto), 08 FG G6E (ZF auto), '10 SY MKII TS Territory (4spd)
LowEL2XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2006, 11:24 AM   #14
naughtyfalcon
ford use and recommend;
EP LS SAE 90
naughty
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2006, 11:51 AM   #15
gthofan
Gunna girlie-man
gthofan's Avatar
how is the standard diff, limited slip diff, and the single spinner in particular different??? how do they all work
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2006, 12:08 PM   #16
Psycho Chicken
Shagged. Join the shagged BW owner's club. Cone packs are crap.
Old 08-01-2006, 12:46 PM   #17
Kenaz
Kenaz's Avatar
I wasn't refering to burnouts in my post before anyone jumps to conclusions. It's mostly turning right.
02 BA XR6 T U R B O
Old 08-01-2006, 12:47 PM   #18
Kenaz
Kenaz's Avatar
Damn! Just as I suspected : thanks Rob.
02 BA XR6 T U R B O
Old 08-01-2006, 04:49 PM   #19
slamd ef wagon
whats it worth?
Old 08-01-2006, 04:55 PM   #20
naughtyfalcon
the standard and single spinner are the same,the lsd has two cone shaped clutches which the axles slide through,,when you loose traction in one wheel it transfers the power to the other,there by limiting the slip,where as a standard or single spinner will just spin one wheel.
hope that helps,,i don't want to quote the whole book..
2000 AU Wagon
Old 09-01-2006, 07:20 PM   #21
mcflux
mcflux's Avatar
http://auto.howstuffworks.com/differential.htm
Describes how different diffs work ;)
Old 19-01-2006, 10:26 PM   #22
FordFan86
meow
FordFan86's Avatar
Sorry to drag this thread out.
I swapped the fluid in my diff awhile ago (3.27LSD) Went down to Sprint auto, told him what I wanted and just to give me the best stuff they had...
SAF-XA
80W-140
Fully synthetic.
Bottle says for all Ford fuel injected V8's XR6T, holden V8's etc etc. $21 for a litre... Liquid gold.
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 10:28 PM   #23
svo347
AFF's 1st DM.......
svo347's Avatar
Liquid gold... Try Redline.
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 19-01-2006, 11:32 PM   #24
tick5.0
Want some classic?
tick5.0's Avatar
SAF-XA
80W-140
Fully synthetic.
I'm using that as well, good stuff, now I can barely hear the diff over the gearbox.....
$21 is cheap, I paid $25.95 a litre.
Originally Posted by Walkinshaw
all i hear is wah wah wah a plastic car is quicker than my boat anchor
EF II XR8, Supercharged manual *** FOR SALE ***
XC Falcon, waiting for the Clevo & C4 - Sold
AE101 Corolla, the daily - Sold
SII RX-7, original - Sold
BF II GT
Alfa Romeo 156 JTS, the new daily
Z31 300ZX Turbo
tick5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2006, 12:43 AM   #25
Simmo
White Lightning
Simmo's Avatar
i use the penrite limslip 80w gear. seemed to help the first time i changed the oil, but my diff is well and truly rooted now.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 12:14 AM   #26
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
redline is great but ing expensive..
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 07:31 AM   #27
BI6TIM
SnortPerformance.com
Redline is clearly the best available but then for the price isn't practicle for most.
Don't much around with that light wieght crap ford recomends, go the 'Penrite Limslip 85W-140'. I've been using this oil in LSD's eversince I've had them and I got 2 years out of a second hand diff ( most of the guys in QLD know how I treat my diffs ).
Any good diff and gearbox builder should recomend this to you.
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 05:14 PM   #28
Rollin
Rollin's Avatar
The additive is a friction modifier - it just makes the oil 'more slippery' - so it will make your LSD more likely to single wheel...just use straight gear oil. LS90 or LSX90 is reccomended, though anything that says it is for BW LSDs is fine - my preference is the heavier the better...
Rollin is offline   Reply With Quote Multi-Quote with this Post
